Lathes seem to have bigger "bangs" than mills – more energy in the rotating bits at a guess.
I was working one bay over from a medium sized CNC chucking lathe in an oil tool plant where the programmer had failed to put a spindle speed limit in a new program. The part was a long steel tube 8" or so diameter, extended well beyond the headstock and supported on a two point roller steady in the aisle. Being an "oil country" lathe it had chucks at each end of the spindle & the exposed tube was covered with a tubular guard to prevent contact with it. While facing the tube in CSS mode, with no spindle speed limit the revs went very high as the tool approached centre, the tube bent 90 degrees throwing the tubular guard down the shop & levering the 12 tonne machine of the floor & turning it 90 degrees to the aisle. Fortunately no injuries, but a very shaken operator.
At the firm I started my apprenticeship with they had a 4 axis (twin saddle) Churchill vertical bed lathe (one of the machines I was set on to learn how to maintain). One of the older apprentices was running the lathe & was on a piece work bonus – I was giving him a hand loading it while he checked the part just removed to get the parts count up. The parts were stainless castings for ball valves & the two saddles were programmed to cut on both the inside and outside of a flange at the same time. Every so often there would be a clatter as the loads on the component from dulled inserts got too much & the flange twisted off to rattle down into the swarf conveyor. After one of these "clatters" there was also a loud hissing noise – the valve component was fine, but all the top slide keep strip screws had stripped & the whole top slide and turret assembly was just hanging on the bent ballscrew – the hissing was from the ruptured hydraulic and coolant flexible hoses. Took a couple of weeks to sort that out !
A former colleague – who I found out after he left in a hurry was referrd to as "Clanger" by the others – left scars on most of the milling machine tables, scrapped a Renishaw probe and (the cause of his "urgent return to Poland on personal business" ) a crash involving a Gildemeister lathe turret running hard into the tailstock barrel. The next user of the machine reported that the turret wouldn't index – which didn't prove too difficult to sort out – but then the hydraulically operated tailstock barrel seized. Long story short, the 100 mm diameter hardened steel barrel was bent. It had to be ground undersize to get the bend out, hard chromed oversize then reground to size & finally have the 5MT taper reground. All because he would not check his programs before hitting the "Go" button & didn't have the feed and rapid overrides set low while proving out a new program.
Nigel B.
