Cleaning Silver Steel
Home › Forums › Beginners questions › Cleaning Silver Steel
  • #284246
    Steve Crow
      @stevecrow46066
      I don't know if this is really a model engineering question but I'm sure someone here can help me.
      I have made 72 struts from 1mm silver steel for a project nearing completion (A model gasometer frame).
      I made them from steel I had in stock which was not rusty but had a dark tarnish. Originally, this was not a problem but now they need to be, if not shiny, at least clean and silver like.
      I could make them all again out of new stock or clean them on the lathe but there are 72 of them. At 10 minutes each that's 12 hours I'll never get back.
      Does anyone know of a magic solution, preferably using domestic products, that I could just pop them in overnight or something? Or an other way of cleaning them all at once?
      Cheers
      Steve
      #8567
      Steve Crow
        @stevecrow46066
        #284251
        daveb
          @daveb17630
          Degrease then dunk in patio cleaner, wash with plenty of water, oil or wax to prevent rusting.
          Dod
            @dod
            A question on a Model Engineers Workshop about a model gasometer, – whatever is the world coming to ?
            #284279
            Brian H
              @brianh50089
              I would have said that a metal model of a gasometer qualifies as 'model engineering'!
              #284283
              Roderick Jenkins
                @roderickjenkins93242
                Interesting. Several people in conversation have referred to this site as the Model Engineers Workshop forum.
                Rod
                #284288
                John Rudd
                  @johnrudd16576
                  Posted by Dod on 14/02/2017 20:18:08:
                  I retracted my thoughts on the grounds of civility…..
                  Edited By John Rudd on 14/02/2017 21:04:51
                  #284291
                    John,
                    I may be mistaken [it has been known], but I think maybe Dod was being clever with the word 'Gasometer' … as being curiosly pertinent to this forum.
                    Composed just before you retracted your comments.
                    Edited By Michael Gilligan on 14/02/2017 21:06:36
                    #284402
                    Ian S C
                      @iansc
                      When you get your Gasometer built, show us a photo, this sounds an interesting model.
                      Ian S C
                      Edited By Ian S C on 15/02/2017 11:35:09
                      #284403
                        Posted by Ian S C on 15/02/2017 11:34:20:
                        Ian S C
                        +1
                        Martin Kyte
                          @martinkyte99762
                          Is it scratch built of of a particular prototype.?
                          Martin
                          #284407
                          Martin Kyte
                            @martinkyte99762
                            "sorry or of"
                            Martin
                            #284410
                            Martin Connelly
                              @martinconnelly55370
                              What you need is something like a pebble/stone polisher used for jewelry. Put them in a closed tub with a suitable polishing medium and rotate slowly for a time. The problem is finding the best polishing medium. Say for instance plenty of 10mm squares of fine emery paper might work or small pieces of sandstone. Mount a suitable tub in a lathe chuck with a slow rpm and leave to tumble while you do something else. You don't want to tumble too fast as they will stick to the outside of the tub due to centrifugal forces. You may need some feature in the tub to "stir" the parts to get good tumbling effects (like the inside of a tumble drier or cement mixer often have plates on the inside of the drum).
                              Tumble and vibratory polishing is used in industry.
                              Martin
                              #284414
                                Walnut shell should polish with minimal wearing of sharp edges, but it is possible that the items could damage each other.
                                Dilute citric should work and in an ultrasonic bath woudl be even quicker.
                                Bazyle
                                  @bazyle
                                  You could research old time polishing of needles (sewing). There is a preserved water powered needle factory in Redditch that is well worth a visit.
                                  In simple terms bundle up wires all together loosely lathered in grinding paste mixture wrapped in canvas like a tool roll but not too tight. Roll it back and forth so the wires rub against each other. Works for needles and you know how shiny they are.
                                  #284422
                                  Rik Shaw
                                    @rikshaw
                                    +1 Neil. Citric acid crystals from the chemist, mix in warm water then dunk the bits. I pickled some ball bearings for the handles on my Harrold Halls advanced grinding rest like this before I silver soldered them on and I found that fifteen minutes was enough to turn them from shiny to a matt grey.
                                    I was puzzled when the pharmacist asked what I was going to use it for. It seems that drug dealers use it for "cutting" their wares.
                                    Rik
                                    #284444
                                    Steve Crow
                                      @stevecrow46066
                                      Posted by Martin Kyte on 15/02/2017 11:41:50:
                                      Martin
                                      It is "inspired" by the recently demolished Hornsey No1 gasometer, next to the East Coast Mainline between Hornsey and Ally Pally. Until it was criminally torn down last year to make way for unaffordable housing, it was considered the oldest geodesic structure in the world. It is even said to have inspired Barnes-Wallis's airship designs.
                                      I wanted to build a gasometer suitable for 2mm scale model rail (2mm to the foot) but even at that scale it would be huge so I've had to compromise.
                                      The one I'm building is 140mm diameter and 125mm high and has 12 columns (Hornsey No1 has 20)
                                      I dry assembled it and it looked so good in its bare metal state that I decided to polish and lacquer all the brass parts, build it on a display base and put it in the living room to gather dust.
                                      It's all ready to assemble now, I just need to clean up the 72 diagonal braces.
                                      I will post pictures soon.
                                      Steve
                                      #284450
                                      Martin Kyte
                                        @martinkyte99762
                                        Brillig.
                                        I think they did list some of them.
                                        regards Martin
                                        #284453
                                        Steve Crow
                                          @stevecrow46066
                                          Posted by Martin Kyte on 15/02/2017 16:19:04:
                                          Brillig.
                                          regards Martin
                                          The Victorian Society tried for years to get Hornsey listed to no avail.
                                          I think the one in Bethnal Green has been listed and there is one in Carlisle.
                                          #284460
                                            Posted by Roderick Jenkins on 14/02/2017 20:28:05:
                                            Rod
                                            As this is the forum for BOTH Model Engineer AND Model Engineers' Workshop so that name is technically as correct as calling it the 'Model Engineer Forum'.
                                            teeth 2
