Posted by Ian P on 10/08/2018 13:43:20:
I too wonder why cast iron is thought to be harmful to lathe slides, even if particles of iron get trapped in felt wipers all they are going to do is lightly rub along the surface.
Ian P
Look closely at what's in cast-iron and it has an unfriendly component, or at least potentially so. It's a wolf in sheep's clothing.
Four things present in cast-iron
- Iron, which is soft.
- Graphite, which is a lubricant.
- Iron Carbides, which are very abrasive. They're what make tool steel hard when heat treated.
- Slag, which is hard
Some cast-irons are alloyed to be harder (contain more carbides) than others, for example to increase wear resistance. Others are alloyed for softness, but we rarely know what we're working with. In manufacture Cast-iron varies between random mixtures used to cast weights and drain covers and a carefully formulated high-end engineering material.
Cast iron castings are famous for occasionally having an extremely hard outer skin. This is partly a mix of sand and slag but mainly is caused by the formation of surface carbides when the mould cools too quickly. A foundry might deliberately make parts of a casting glass-hard by force cooling the mould, but the same can happen by accident…
Carbide particles from chilled cast iron are murder on soft metals like mild steel, so it's best to clean up.
