Clarke CL500M Mounting Dimensions
Home › Forums › General Questions › Clarke CL500M Mounting Dimensions
  • #248054
    Howard Lewis
      @howardlewis46836
      Am helping a friend to set up his CL500M. I want to mount it on two pieces of box section, on a substantial bench, to set it up with no twist in the bed.
      The manual does not show the dimensions for location of the mounting holes, and the Machine Mart Technical Dept are unable to provide the info. from their data.
      Can anyone please help?
      #24656
      Howard Lewis
        @howardlewis46836
        Dimensions needed for the mounting holes, please
        #248061
        MW
          @mw27036
          Hello Howard,
          I own a CL430, which is basically the same without the mill head and i've bolted it to a bench so i could probably go and measure the distances. I can't garuantee they'll be completely accurate because when i put it on my bench i just pointed a power drill down the hole and bolted it to where ever it came out the other side!
          I'll get back to you with that.
          Michael W
          #248062
          MW
            @mw27036
            Right, so i've gone and measured with a tape measure, to get 7" inches across and 21.5" inches longways, thats without taking the centres into account, the bolts are M10 so minus the radius of both those holes, is 7 inches (177.8mm) -10mm would be 167.8mm between centres.
            For long ways of 21.5", just doing the same 546.1mm -10mm to give 536.1mm between centres, there was a beam in the way with this one so i'm a bit unsure about how accurate thatll be.
            Hope that gives you a ballpark.
            Michael W
            Edited By Michael Walters on 25/07/2016 15:49:56
            #248070
            Howard Lewis
              @howardlewis46836
              Many Thanks Michael.
              Now to go and look for two lengths of suitable box section on which to mount it.
              We'll need some M10 studding and nuts, so that it can be set up level in both planes. Less worried about Head to Tail, but keen to make sure that the bed is not twisted, so that it turns parallel..
              Once again, many thanks!
              #248107
              MW
                @mw27036
                No problem Howard, any time.
                Good luck with the installation, hope he enjoys his new machine, tis' a sturdy beast!
                Michael Walters
