Chipmaster question
Chipmaster question
Home Forums Manual machine tools Chipmaster question
  • #181536
    charadam
      @charadam
      I posted this on the Yahoo user group, but no response as yet.
      Can anyone define the crossfeed screw for me in terms of diameter, thread form, pitch, hand and length?
      The lathe is Imperial.
      I want to replace the screw soon but cannot strip the lathe at the moment.
      Thanks in advance,
      Charles
      charadam
        @charadam
        #181542
        Raymond Hodges
          @raymondhodges20973
          Hello Charles
          Try this site maybe they can help http://www.lathes.co.uk/chipmaster/index.html
          Good luck
          Ray
          Edited By Raymond Hodges on 27/02/2015 20:38:24
          #181548
            I found a post that says the cross slide screw is a ACME 3/4-5TPI on a Student.
            Tony Ray
              @tonyray65007
              Charles,
              I can tel you that it's left hand twin start. If you are going to replace the screw you would be advised to change the nut as well. You can get these parts from 600 group but may find Robert Pringle based in Harlow are cheaper but still prepared for a shock.
              #390584
              norman royds 2
                @normanroyds2
                I ALL having trouble with my Colchester chipmaster clutch is slipping but I don't think it is the clutch there is a lot end play in the shaft it self and the clutch housing .and there is no information in the manual that I bought from tony Griffiths or in manual that came with it .so is there anybody out with the information that can help me there must be some worn parts or bearing I thought it was the variator but I have changed the oil in variator . thanks in advanced for any information regard nome
                #390598
                Emgee
                  @emgee
                  Charles, have looked at the manual and can only advise part numbers, but there is a choice of Eng or Met and std or anti-backlash nuts.
                  The manual is available on Yahoo Groups Colchester Lathes group.
                  Emgee
                  #390602
                  norman royds 2
                    @normanroyds2
                    thankyou I will have a look on yahoo regard norm
                    #390704
                    norman royds 2
                      @normanroyds2
                      No look on Yahoo page seems to be out off use .I have tow manual but no technical information I look on ebay and the manual look the same has so back you hope you can help me regards norm
                      #390728
                      Pete Rimmer
                        @peterimmer30576
                        I think the chipmaster is the same as the Bantam, 9/16" diameter 10tpi pitch .200" lead left hand 2 start. I could possibly be able to knock out an EN8DM threaded blank to splice into your screw but I'm really busy right now. They are expensive because of the integral gear which I could also probably hob but if it is the sliding spline type, I have no cutter for the spline.
