Hi John M
I take it that when you applied power to the mill with the potentiometer disconnected the motor did not spin up. If the motor was stationary then this could mask a problem with the motor/motor feed or possibly even the drive circuitry. That said it is worth looking at the potentiometer its cabling and the area where it connects to the motor control board.
Without readily being able to conduct electrical tests then it will initially be visual only. Check the pot connections and as much of the interior of the pot as can be seen for any sign of contamination. Then examine the connecting cable for signs of damage and finally thoroughly check areas around the connections on the motor control board for any spurious material. The main culprit is likely to be very fine metal slivers or dust that is creating an intermittent low current short circuit, I take it the the main fuse doesn't blow when the RCD trips out.
If nothing is apparent then do as John R suggests reconnecting the pot and see if the fault is still there, should it run fine then there is a fair chance that you have disturbed some foreign matter. If the fault reoccurs it may well be worth while replacing the pot, how's your soldering?, as this will be the cheapest and easiest first point to start with.
The reason I asked about the motor running is that if the is some earth leakage on the motor or its cabling is that if it is not powered then there will be no leakage to earth and the fault will not show. A quick question, how far did you go when inspecting the motor for carbon brush dust?
Martin W
edit; PM sent
Edited By Martin W on 28/11/2018 19:16:43
