CE mark
CE mark
Home › Forums › General Questions › CE mark
Viewing 25 posts - 1 through 25 (of 57 total)
  • #243954
    DMB
      @dmb
      Given todays news, presumably the requirement for a CE mark is now redundant on any goods sold in the UK?
      Including boilers?
      #24602
      DMB
        @dmb
        #243955
        Bazyle
          @bazyle
          Never wish for a regulation to go away. It will inevitably be replaced with something more onerous, more restrictive, and more asinine as the pen pushers in charge want to show how important they are.
          #243959
          John Rudd
            @johnrudd16576
            Ok,
            So we are leaving the EU, as the op stated, the CE mark may/will no longer be required but ought to be replaced….
            What was in place prior to us joining? If it was good enough then, surely its good enough moving forward? (British Standards perhaps? )
            #243961
            Simon Collier
              @simoncollier74340
              I read my July EIM today. There was a very interesting add about why model engineers should vote to leave. It concentrated on the EU rules for boilers and the switch to more expensive, poorer performing 55% silver solder. I was surprised and delighted to see it. I doubt Neil would have allowed it in MEW.
              #243963
              duncan webster 1
                @duncanwebster1
                Any pressure vessel built to British Standards would have no problem being CE marked, and any competent company would have no difficulty complying. If you doubt this go and read the European Pressure Systems Directive. Do not imagine for one second that the HSE or insurers will allow commercially produced pressure vessels to be used without proof of good design/construction. Something else will be brought in, and it will probably be more onerous
                #243965
                MW
                  @mw27036
                  I think it will stay or have atleast a british replacement, we wont see that for many years but maybe someday. The mark is good for trade so many will keep it even if they aren't obliged to use it.
                  The B.S.I is and was an excellent institution that pretty much provided the the entire basis on standards we should be proud of. It wasn't in the pockets of cronyism like alot of other countries standards were, simply bent to their own purposes and obeyed/ignored at will.
                  Our system stands alot more to reason and fact to protect the quality of the actual product and therefore it's users also. Alot of the I.S.Os seem like a carbon copy of the old BSI standards. But, all the more reason to be proud of just how good a system it was.
                  Michael W
                  Edited By Michael Walters on 24/06/2016 10:40:22
                  #243967
                  Circlip
                    @circlip
                    Hopefully a return to the superior leaded soft solders for electronics, but don't forget, where money is the prime consideration, the social do gooders will retain the most lucrative rules.
                    Regards Ian.
                    #243968
                    MW
                      @mw27036
                      Posted by Circlip on 24/06/2016 10:41:49:
                      Regards Ian.
                      I'm a little confused by what you mean by better. Perhaps leaded soft solder provides a superior bond but i haven't found it flows better, if anything the cored solder i've found to be the easiest to use, i think theres mainly tin in that.
                      MIchael W
                      #243969
                      Circlip
                        @circlip
                        Unless it's changed, "Ersin multi core" was 60/40 tin lead in general use. How many of the far easts manufactory of products lie dormant due to brittle joints?
                        Regards Ian.
                        #243970
                        Muzzer
                          @muzzer
                          If you actually dealt with the regulations rather than read about them on the front page of a comic, you'd know that CE marking simply declares that you have met all the applicable safety standards that apply within all the countries in Europe. This is actually a Good Thing:
                          Whether you talking about US, Canada, EU, Scandinavia, Korea, Japan, Australia or wherever, you are legally obliged to obtain any applicable safety certification before you may sell your products in that country. I know, because I've spent the last 30 years doing just that. Before the CE mark, it was necessary to get products approved in each of the EU member countries you wanted to sell in (UK, Germany etc etc ….). Now, one mark does it all (within EU) and the standards within Europe have been "harmonised" to cut down on the regulatory work. Doesn't play well with the EU bashers though, who like to present it as the exact opposite. Of course, you still need to have your products approved for all the other markets that aren't harmonised. It's expensive and time consuming and is far from just a formality, as you often have to make late changes to the product to comply.
                          Unless we plan to completely stop selling products to Europe, we will still need to CE mark.And even if we get rid of the CE mark within the UK, any standards that replace it will be almost indistinguishable. Over the years, harmonisation has been a global process so that the requirements for the N American and European markets have converged. It's sensible really, as the requirements are based on decades of knowledge and experience, often based on actual death and injury.So for instance, the global generic electrical safety standard is arguably EN 60950 / BS EN 60950 / UL60950 / CSA 22 etc etc. Call it what you will but it's all based on IEC 60950 which has much of its roots in our old BS stds.
                          The IEC that sets these standards was originally formed in the UK to coordinate international safety standards. Nothing to do with the EU, I'm afraid.
                          Murray
                          #243971
                          David lawrence 3
                            @davidlawrence3
                            I used to repair a lot of European and uk made photographic gear as a living, all the Europe stuff was very well made, passed all the ce checks etc, the Chinese gear that started to come into the uk 6 years or so was cheap, poorly made, had no earth, wrong mains lead colours, all had CE stamped on the case, no chance of passing anything but we let it in the country. perhaps now we stop this rubbish coming in. The CE stamp made lots of UK companies spend lots of money to get approval, China bought a rubber stamp.
                            #243972
                            Nick_G
                              @nick_g
                              Posted by Michael Walters on 24/06/2016 10:54:18:
                              MIchael W
                              How long do you think cored solder has been around.? – It's certainly not a new product that was brought out to meet new regulations.
                              I recall using it as a young lad in the early 70's. No doubt someone more senior to me will tell us when it was first introduced.
                              Nick
                              #243973
                              Roderick Jenkins
                                @roderickjenkins93242
                                Europe hasn't gone away surprise. If we want to export to the EC then we still have to comply with CE markings, as will China. and the rest of the world. The UK will continue to use all existing regulation unless there is a very good reason to introduce something different, which will need Parliament to change the rules.
                                Solder is a case in point – I don't suppose manufacturers are going to run 2 different production lines with differing solders. Anyway, traditional Ersin 60/40 resin cored lead solder is readily available in my local DIY shop for use in the home workshop.
                                Rod
                                Edited By Roderick Jenkins on 24/06/2016 11:13:52
                                #243974
                                MW
                                  @mw27036
                                  Posted by Nick_G on 24/06/2016 11:11:20:
                                  MIchael W
                                  Nick
                                  I just was confused thats all, i have a reel of 60/40 pure tin/lead and it doesn't flow readily and presumably the better stuff i was referring to was just the roisin cored equivilent.
                                  Michael W
                                  #243977
                                  Jon Gibbs
                                    @jongibbs59756
                                    +1 for Muzzer's comments.
                                    Jon
                                    #243981
                                    Martin Kyte
                                      @martinkyte99762
                                      The reason for moving to lead free solder for electronics was and is to reduce the heavy metal leaching into the ground water around landfill. This became a problem with the high increase in dumping of consumer electronics. Lead in the environment is also the reason we are all driving on unleaded petrol. It's cleaner all round. There is no ban on selling 60/40 leaded solder only restrictions on sale/disposal of electronics built with it. We (our workshop) generally does not use lead free because we don't build stuff to sell and we operate by hand soldering assembly processes. The vast majority of joints in electronics are automated and lead free does not pose problems.
                                      regards Martin
                                      #243982
                                      Ian S C
                                        @iansc
                                        Rosen cored solder has been around for quite a while, it was first patented in USA in 1929. It is not mentioned in my oldest ARRL Radio Amateur's Handbook, but in my copy of the RSGB The Amateur Radio Handbook 2nd ed 8th printing 1943 (1st print 1940) it is mentioned, and recommended, and I know that dad used it before the war when he worked after school repairing radios for a radio sales company in Dunedin (NZ). Ian S C
                                        Edited By Ian S C on 24/06/2016 12:14:54
                                        #243984
                                          I just cut a strip off a small circuit board … then realised I was probably breathing in lead dust
                                          This is interesting:
                                          http://www.quantumalloys.com/data/electronic/erzin.html
                                          not done it yet
                                            @notdoneityet
                                            The big joke is often that CE marks on chinese products simply stand for 'China Export' and nothing to do with european safety standards. Sure, there are good Chinese products, but there are also some really dodgy items which still need to be weeded out on arrival for sale.
                                            The fact that the (genuine) EC marked products are up to, and often beyond, the old BSI kitemak system is to be lauded.
                                            #243986
                                            Ajohnw
                                              @ajohnw51620
                                              Posted by Roderick Jenkins on 24/06/2016 11:11:47:
                                              Rod
                                              Nice and precise Rod. The same thing will apply to just about everything we might buy. In order to sell into the EU what ever standards they choose to have will still apply to all goods that are sold there. In the past this area has been used for protectionism and there may even be a growth in that now.
                                              mechman48
                                                @mechman48
                                                We used to have the BS Kite mark; this ensured that all items were all tested to the highest BS compliance requirements before it was usurped by the CE logo, it was more than good enough then so why not return to the same standards, & put our Kite mark back on items.
                                                George.
                                                #243995
                                                Russell Eberhardt
                                                  @russelleberhardt48058
                                                  Posted by duncan webster on 24/06/2016 10:34:41:
                                                  Quite. That's because the British Standards are now just the Normes Europeans with different covers. I used to work on BSI committees and later all of the work transferred to the European ones with more or less the same people involved.
                                                  We can't go back to the pre-EU British standards as they are hopelessly out of date and we would have no chance of exporting anything.
                                                  As far as restrictions on the use of cadmium (for example in Easy-Flow) is concerned, I remember in the early 1970s having to change from cadmium plating on metalwork to zinc plating, as the Swedes had banned it pre-EU over concerns with cancer.
                                                  Russell.
                                                  #243998
                                                  Raymond Anderson
                                                    @raymondanderson34407
                                                    It is certainly easily for the unwary to get confused with the CE mark and the CE mark The one that means CHINA EXPORT has very subtle differences, and is not readily apparent.
                                                    #244000
                                                    Ajohnw
                                                      @ajohnw51620
                                                      Posted by mechman48 on 24/06/2016 13:23:11:
                                                      George.
                                                      And employ a load more people to work at BSI ?
