"the inserts pictured are totally different. Ones a polished insert with a small rad and ones coated with a large rad."
Of course, no dispute I can see that.
"My own experience of inserts from China, is that similar geometry etc gives similar results."
Similar results doing what though? The particular application I had was to fine turn silver steel to be a precise fit in a bored hole. Those unbranded sintered tips would not allow that. I'm in no position to question whether such Chinese tips with the same tip geometry as the Iscar ones would have permitted <0.001" cuts. I haven't tried. I simply purchased the Iscar tips and found they did the job I needed.
Then as for "Try mounting a 3" diameter plus steel or hard skinned cast iron bar in the chuck, run the S7 flat out, and take a fast cut, at least 250 thou deep."
I'll pass on that. The Myford does all I need which excludes having to take enormous cuts in 3" chilled CI.
I am a regular user of HSS lathe tools but possibly due to my inept use of the Quorn to sharpen them accurately, I cannot obtain the surface finish on Ag steel (with or without Garia H lubricant) that the Iscar tips generate dry.
At risk of repitition, I was attemptng to relate my experiences in using my lathe accoridng to my particular 'hobbyist' needs. If others should find anything of value in recounting those experienes so much the better.
