It's easy to forget the precise mechanics of what happens when you drill with a jobber drill. The chisel edge in the centre of the drill has a huge negative rake and will not cut the metal; it has to gouge it out by plastic deformation. The force needed to do this can become very large indeed as the drill diameter (and hence the size of the chisel edge) increases. Using a pillar drill, the leverage applied by the feed handle is substantial. and one might not realise just how substantial; using a hand-held drill, the force has to be applied by you pushing it.
As you found, a pilot hole (sized about the same as the width of the web on the larger drill) will remove the need to force the chisel edge into the steel and make the job much easier.
David
Edited By David Littlewood on 16/12/2012 19:57:10
