Building Bernard Tekippe’s Precision Regulator
Home Forums Clocks and Scientific Instruments Building Bernard Tekippe’s Precision Regulator
Viewing 8 posts - 126 through 133 (of 133 total)
  • #800595
      A difficult choice, Chris … The escapement sounds good to me, and the expedient option is to not start tinkering.
      But the ‘vibration tester’ in me is wary about that big overhang
      Will vibrations in that arbor get fed into the ‘scape wheel, and if so what might be the effect ?
      Frankly, I don’t know
      gerry madden
        @gerrymadden53711
        Hi Chris, I didn’t want to say anything earlier as it’s so difficult to make accurate judgements from videos, but when I first watched your second-to-last video, I was thinking to myself at 18:10 that the scape-wheel arbor was not looking as free I thought it should be. After being given a nudge, the wheel seems to stop quite suddenly. That’s often a sign of excess bearing friction.
        Three things could be causing this. One is misalignment of the two support positions, (as previously discussed). The other is your housing fits are too tight and/or out of round. Finally you might even have some bearing-to-bearing preload.  **
        Unfortunately without a detailed engineering drawing showing positions of abutments, dimensions etc, it’s difficult to pinpoint your issue/s, so my feeling is one really has to sort this out by trial and error investigations.
        I would probably start by looking at those housing fits which I’m really not happy about. If your housing holes are just drilled, they WILL have significant shape errors. If the rings are ‘press fits’ in these drilled holes, these shape-errors will easily be transferred through the rings into the raceway/ball-set where they will cause all manner of nasty effects. So you really need to aim for a loose-fits on these outer rings. One should really talk about machining to specific diameters, but since that’s not really practical in this environment, the next best thing could be to use fine emery paper to gradually ease the hole. You should aim to get to a point where the outer-ring will just slide through it.  A poorly shaped loose-fit hole is far kinder to the bearings than a tight poorly-shaped one.
        If you are currently using the tight housing fits to locate/secure the shaft assemblies axially, you may now need to add a small abutment plate or two in the appropriate positions to keep everything in place. Try to arrange it so that just ONE of the two bearings on the shaft, locates it axially. This will ensure you don’t end up with the two bearings fighting each other.
        With regard to your reduced-span support modification, from the point of view of loading, you need not have any concerns. The load capacity of these bearings is way in excess of the forces that a clock mechanism can impose. I would be more concerned about the alignment. Reducing the span between the bearings is likely to increase the misalignment angle which is critical from a friction point of view. However if you take the steps on the housings outlined above, misalignment issues will be mitigated.
        Gerry
        ** just thought there may be a forth, grease. Were these ‘degreased’ bearing that you are using? Regardless, I would still focus on the points above as these aspects must correct if we are ever to get the optimum low-friction performance from these rolling element bearings.
        #800728
        steve7750
          @steve7750
          These are all excellent points, Gerry.  I’d mentioned to Chris on his other thread that the preference would be to keep the front bearing between the escape wheel and hand to spread the (admittedly tiny) load.  The train is really sensitive to the smallest resistance especially at the escape arbor.  It can be stalled by the merest hint of friction.
          Our plate holes were all drilled undersize with end mills and then reamed, to try and keep everything where it was designed to be.
          Ours has the hybrid ceramic bearings which had to be thoroughly degreased in acetone, or they were just too sticky.  Time will tell if there is a corrosion issue, but being stainless we should get a decent lifetime to test things out.
          #800734
          Chris Raynerd 2
            @chrisraynerd2
            Hi Michael
            Vibrations I certainly have. The clock seems to be running well but the pendulum seems have a strange vibration or judder!
            It is very strange.
            Gerry
            Thanks for the great response Gerry. I have gone for a tighter bearings on the ID as it was discussed that the arbor looked too lose on the inner ring. The holes were drilled and reamed out and the bearings a great fit – just clear to hold them but with almost no pressure on the OD of the bearing.
            If it stops again, the next plan is to remove all the bearings and clean them. I admit, I posted a while ago about degreasing bearings and then with all the issues I had ordering more, I’m worried one has slipped in that is still greased!
            I just need to slow it down a bit now. No point going any further until I have the clock running.
            Chris
            #800736
            steve7750
              @steve7750
              Hi Chris,
              Bernie’s design of minimal cross section does make for a very whippy pendulum.  If it wasn’t doing this when you first started it (which can happen if the Bob is released too quickly), what you’re seeing is the result of a “misfire” when you weren’t there.  The escape wheel didn’t cleanly drop to the pallet, but hung up on the way.  The other incoming pallet kissed the tip of a tooth and sent a shudder down the whole assembly which will reverberate for ages.  The escape wheel freed up and the running continued.
              Once you have a Microset on it, you’ll be able to catch these things, but these events certainly don’t do any favours to the suspension spring, escape wheel teeth or pallets.  You need to try that run down test I mentioned earlier, to make sure the train is totally free.
              #800738
              Chris Raynerd 2
                @chrisraynerd2
                Thanks Steve
                Interesting points made. You have mentioned the run down test a couple of times and apologies for not replying. It is always one of the first things I do when I have depthed the train. It seems to be lovely and free! There may be a few spots where it varied in speed a little, but with such small weights applied, it seemed incredibly free!
                #800740
                  I would say that the wooden back-board is very likely contributing to the disruption of the pendulum … a good solid wall would be a better mounting point.
                  steve7750
                    @steve7750
                    I did find an old video of ours after a similar incident.
                    https://youtube.com/shorts/tza2mUYaYfY?feature=share
