Posted by Keith Matheson on 20/12/2020 08:49:21:
… the view seems to be the lathe is simultaneously in both states. (It’s OK, it’s not OK) when I use the lathe doing this/ not doing this, the lathes wave function will collapse into either- many happy years of usage OR a bust control board. I think I will flick a coin! LOL On balance I think I will let it slow down under its own steam just in case. …
Don't flick a coin – understand why the answers conflict! There are a multitude of motor combinations fitted to lathes, all with different characteristics.
JasonB and I own WM280 lathes and Keith has a ToolCo1130. Although the iron is much the same, our motors and control electronics are completely different:
- Jason's WM280 is fitted with a DC Brushed Motor and an electronic speed control that converts 240vac into pulsed DC,. Speed is controlled by altering the ratio between pulse on and off times.
- My WM280 is fitted with a 3-phase AC motor and a Variable Frequency Drive (VFD). 240vac is converted electronically to a kind of synthesised 3-phase, and motor speed is varied by altering the frequency. VFDs often apply advanced features like regenerative breaking, wave-shaping to put more current into the motor at slow speeds, and optimising efficiency and performance across a desired range of loads and speeds.
- Keith's ToolCo1130 is fitted with a so-called 'Brushless DC' motor. Despite the name these are more closely related to 3-phase motors than brushed DC motors, in that their coils are phase energised electronically. They might be said to combine the advantages of 3-phase and brushed DC motors – excellent torque and speed control, coupled with high-efficiency.
Three very different set-ups all worked by a speed-control knob and on/off switch. Look similar, but how it all works under the bonnet is disparate.
The PWM controllers on a brushed motor are stressed by power-cut stops and high-speed starts. Plenty of evidence of mini-lathe and small mill owners popping their control boards by smacking power on & off rather than taking speed up and down gently on the pot.
A VFD controller might be smart enough to manage both snap power-on & off operation. For example regenerative braking is often applied to take energy out of a potential accident when the operator does a hard-stop. Unlike most inexpensive PWM controllers, a VFD is likely intelligent enough to handle it. Or not!
Brushless controllers have even more options that VFDs, but whether or not they're used on a particular lathe is unknown. They might be happy.
While it's possible to give general advice about old-fashioned motors and controllers, modern set-ups are less predictable because they're more advanced. Without understanding the design and configuration used on a particular box of tricks the operator doesn't know! And nor can anyone else on the forum.
My view is Hobby Machines are unlikely to be designed for snap on/off operation. Their electronics are designed to cope with the occasional emergency stop, not to speed-up stop-starts as an operator convenience. Unwise to set the speed and then just switch on and off! It's equivalent to pulling away in a car by red-lining the engine and dropping the clutch with a bang, and then stopping from 70mph by shifting gear from 5th to reverse.
My advice is to always Start and Stop with the speed control in the lowest position because it minimises the risk of blowing expensive electronics we don't understand. Unless the manual says different! Professional machines may be OK with Mr Bean at the controls – they're designed to work fast and hard, and might well include several hundred pounds worth of bulletproof electronics.
