Hi Andrew,
For more info on brazing go to **LINK**
Read it – load your printer – print it – and read again. Keep it by you. It will set you on your way to successful brazing with a clear understanding of what to do, why you have to do it and how to do it.
Do it right and the joint will be stronger than the parent materials,
You may not elect to use silver solder as your filler metal but a brass rod instead. No matter, the principles are identical. You are still brazing.
If you require any further help, then come back to us.
Keith
