As NDIY says probably lack of lube. I never use my back gear now with the VFD but still give it a spot of oil now and then just in case. I always found when I did use it that a little twist of the chuck helped the engagement. I am sure you are aware that there are 2 oil points, 1. the hole above the back gear lever & 2. the oiler in the centre of the shaft in the housing.
regards
Author
Please log in to reply to this topic. Registering is free and easy using the links on the menu at the top of this page.
