Boiler lagging
Boiler lagging
Home Forums General Questions Boiler lagging
  • This topic has 17 replies, 12 voices, and was last updated 24 May 2021 at 13:35 by duncan webster 1.
  • #540535
    Garry Coles
      @garrycoles69390
      Hi, The time has come to think about lagging the boiler on my 2 in D & NY traction engine. I have some kerwool which is about 1/4 in thick. But its to thick to use. Has anybody used anything else, like thick cardboard. Will the heat be to much for this type of material. Some of you will say, why don't I just buy some thinner stuff. Well the price may not be a lot, but the postage costs to Jerey are.
      Any thoughts please.
      Garry
      Garry Coles
        @garrycoles69390
        #540537
        J Hancock
          @jhancock95746
          The coefficient of heat transfer for Balsa wood is impressively low.
          #540539
          Harry Wilkes
            @harrywilkes58467
            Hi Garry
            On my 3" Burrell which I,m about to do there are 2 layers I would say without getting the rule out one is around a 1/4 the other 1/8
            H
            #540543
              On a model locomotive boiler I feel insulation is more a statement of intent than likely to deliver a marvellous improvement! Some materials will be better than others, but they are all too thin to do much good. The insulation on a domestic immersion heater is 2 or 3 inches thick, and that's not fully effective either, even though the water is well below boiling point. Good insulation is bulky.
              Always well worth having some insulation, but I wouldn't get too excited about the exact material or thickness beyond more is better! Most materials apart from soft plastics will withstand boiler temperatures, but Cerwool can't go wrong because it's made to get very hot! Can't find any Thermal Conductivity figures for it, but as it depends on trapped air, I guess it's similar to Balsa, which should be fine on a 200psi boiler.
              Be interesting to experiment with various materials to see if any are outstanding, but I suspect the thermal performance of all common insulators at model scale thickness will be spoiled by the layer's thinness.
              MichaelR
                @michaelr
                Hi Garry,
                On my Durham & NY I used Glass Fibre chopped strand mat, the type used for car body work patching, I had my engine a lot of years and the lagging showed no problems.
                MichaelR
                #540546
                  Not sure about thickness Dave, take a look at some of the multi layer house insulation products.
                  Two layers of 1/16" Kaowool with a sheet of tin foil between is a popular choice for 2" engines. Unless you have something handy I suspect postage costs on most things will be similar.
                  #540554
                  Garry Coles
                    @garrycoles69390
                    Thanks everyone. I will probably use some thick cardboard.
                    #540564
                    Bazyle
                      @bazyle
                      re cardboard, think about whether water will get in Even if it dries out next steaming will it affect the integrity of the material?
                      #540571
                      duncan webster 1
                        @duncanwebster1
                        The insulation is provided by the trapped air. What the insulation material (Kaowool etc) does is prevent convection, conduction through air is very low. Scrunched up aluminium foil is pretty good, or corrugated cardboard (not very water proof). Cork is pretty good as well, floor tiles?
                        #540673
                        Daggers
                          @daggers
                          I need some thin lagging in the end i purchased Kiln Glass Paper which is 1mm thick. I purchased a pack 50 pieces 80mm square for £5 just butted some sheets using double sided tape then brass cladding. Worked really well.
                          #546697
                          Brian Abbott
                            @brianabbott67793
                            Hello All.
                            Anyone know a stockist for the 1/16" thick Kaowool insulation?
                            Thanks
                            #546701
                            duncan webster 1
                              @duncanwebster1
                              ceramic paper
                              but it's comfortingly expensive. A phone call to explain what it's for might produce a sample. Otherwise find furnace engineers in your local yell and cadge some from them
                              or let ebay be your friend rcAAOxy4fVTB3xZ”>cheaper
                              However I've no idea of its insulation properties
                              Edited By duncan webster on 24/05/2021 00:36:36
                              #546772
                              bernard towers
                                @bernardtowers37738
                                If it’s kaowool I split mine down on my DNY so it is about 5/32 thick.
                                #546773
                                bernard towers
                                  @bernardtowers37738
                                  #546783
                                  Brian Abbott
                                    @brianabbott67793
                                    Thanks Duncan.
                                    I have ordered a roll of the 1mm,
                                    As i only need a couple of meters if anyone needs a small amount for a project then drop me a message, token gesture towards the cost plus postage.
                                    Thanks.
                                    #546794
                                    Robert Atkinson 2
                                      @robertatkinson2
                                      Posted by duncan webster on 24/05/2021 00:34:14:
                                      ceramic paper
                                      or let ebay be your friend rcAAOxy4fVTB3xZ">cheaper
                                      That ebay listing is much more expensive, £22 a meter compared than £2.83 !
                                      #546809
                                      duncan webster 1
                                        @duncanwebster1
                                        But if you only want a metre it's cheaper to buy from FleaBay
