Boiler housing
Boiler housing
Home › Forums › General Questions › Boiler housing
  • #24553
    Mark Salzedo 1
      @marksalzedo1
      Boiler housing
      #239361
      Mark Salzedo 1
        @marksalzedo1
        Hi,
        I would be grateful for some advice regarding boiler housing. I have a fairly large steam plant and the housing surrounding the boiler is definitely not metal. It is about 2mm in thickness and when you press it it bends a little. It is black but has probably been painted. I am concerned that it may be asbestos. There are white deposits around the boiler and especially at the gas inlet end of the boiler. The boiler is fired by two 3" diameter ceramic burners. I have provided some photographs which may offer some clues?
        In any event, whetever the housing is made of, I plan to remove it and replace it with a metal housing to support and surround the boiler. I have plenty of mild steel plate which might be suitable but this would probably conduct the heat away from the boiler pretty rapidly, unless it could be painted with some sort of heat resistant paint? Is this a possibility?
        If it is asbestos, presumably the best way to remove it is to work outside, wear a mask and not to break the material but carefully remove it and dispose of it accordingly.
        Any assistance will be appreciated.
        Thanks,
        Mark
        #239378
        pgk pgk
          @pgkpgk17461
          I can't think of a simple way to identify asbestos compared to some of the modern fireproof fibreboards. Indeed i understand some of the older vermiculite boards will have a percentage asbestos in them. I'm sure there's guys here better qualified to comment.
          Painting steel sheet with fireproof paint won;t stop it conducting heat away..just stop the paint burning. I'd have guessed at using new known fireboard or other insulation under any new sheeting you apply..
          If you do strip off old board that's asbestos then you can't just take it to the dump and chuck it.
          #239395
          Michael Topping
            @michaeltopping17870
            Are you sure it is not al. alloy sheet? Looks a bit like it and the white residue is typical of aluminium corrosion.
            Michael
            #239396
            Mark Salzedo 1
              @marksalzedo1
              Many thanks for both of your replies. I contacted the person I bought it from and he says that it is alloy sheet lined with white boiler insulation material to conserve heat but he doubts whether it is asbestos.
              You think that the white residue is alloy residue rather than anything to do with asbestos? Presumably if it was lined with asbestos it wouldn't leave these kinds of deposits? Also if I were to change the boiler housing what would be the best material – brass?
              Many thanks.
              Edited By Mark Salzedo 1 on 19/05/2016 20:49:16
              #239490
              Michael Topping
                The white residue definitely looks like aluminium corrosion. If was replacing the housing I would use zintec steel sheet. Lot cheaper than brass and takes paint well.
                Michael
                #239502
                duncan webster 1
                  @duncanwebster1
                  I agree that Zintec would be a good material to make housing from, but we used it for truck sidesheets and have had the devil of a job getting paint to stick, even using etch primer.
                  #239540
                  Mark Salzedo 1
                    @marksalzedo1
                    Much obliged for the information. This is most helpful. I understand now that the lining inside the boiler housing is Kaowool blanket. Does this give off white residue over a long period of time. If it is Kaowool, I will probably just clean up all the white deposits and repaint the boiler housing.
                    Also, I have just noticed that there are six nutted stays (visible in one of the pictures in the album), but they are not soldered. Is this acceptable for home use? The previous owner said that the working pressure of the copper silver soldered boiler is 80 psi with two safety valves fitted. He reports that he ran the boiler without any problems.
                    I did have a word with someone who professionally inspects model boilers and he mentioned that this is not uncommon practice (nutted stays without being soldered).
                    I would be grateful for advice from those who are more experienced with model boilers.
