Bantam Coolant Tank Capacity?
Home Forums Manual machine tools Bantam Coolant Tank Capacity?
  • #281662
    Steve Addy
      @steveaddy35670
      I have a Colchester Bantam 800 which I was wise enough to buy new when I was single, young and a non-householder in 1979.
      I want to know the capacity of the coolant tank is, as although I have the original manual the capacity isn't mentioned. The lathe would have to be moved to enable me to measure it.
      If anyone can measure theirs easily for me I'd be grateful.
      Steve
      Steve Addy
        @steveaddy35670
        #282059
        John Stevenson 1
          @johnstevenson1
          Sorry for the delay, it took me 3 days to find it as it's not on the machine.
          So this one off a 1600 is 16" long, 6" wide and 6 1/2" high which in my book is 624 cu in
          And Google tells up that equates to 2.2493 gallons but that doesn't take into account the displacement of the coolant pump pick up and that's also full to the brim so reckon on a short 2 gallons ?
          #282429
          Steve Addy
            @steveaddy35670
            Hi John.
            Thanks very much. I have come back on tonight to report that I have just removed the splash back from my machine to measure it and also dipped the tank through the tray drain to see how deep 4 litres was.
            The answers to the questions are: –
            Dimensions – as near as it is possible for a dwarf to measure hanging over the machine, 6" x 6" x 14".  I cannot be sure of the 14" but it is at least that for the tray drain to work. In metric this is 150mm x 150mm x 355mm, giving a capacity of almost 8 litres, neglecting the pump parts.
            These dimensions are verified by a dipped depth of 75mm in the tank from 4 litres. 75mm x 150mm x 355mm comes out as within about 6cc of 4 litres.
            I'll get some more coolant at the next show I attend – it will be fine with 6 litres in there.
            Steve
            Edited By Steve Addy on 04/02/2017 20:23:01
