Posted by SillyOldDuffer on 18/07/2018 19:11:07:
A fly-press is a really good way of delivering a consistent blow to a die or stamp. Unfortunately I don't have room for one.
Richard's requirement could be met by any other way of delivering a straight blow to a stamp aligned with the work. With practice it can be done with a hammer, though I find it's not easy to acquire the knack of keeping a stamp straight while hitting it just hard enough to do the job.
An alternative might be to drop a weight down a pipe arranged to ensure that the weight hits the stamp square with a measured blow. The size of the blow delivered is determined by the size of the weight and by how far it falls. Once found, the blow can be repeated exactly. Like operating the fly-press, gauging the necessary violence (the drop) has to determined experimentally.
Not as easy as a fly press but the arrangement takes up less space.
Edited By SillyOldDuffer on 18/07/2018 19:12:53
Thanks Dave. I did think about this a lot. Unfortunately as our hobbies have only been wood +Aluminum based, we just don't have any materials lying around to fabricate such things – I did actually sketch out a design for something similar to what you describe so I could price it up. Unfortunately it came ou to not much less than a fly press, with obviously much less flexibility. Room isn't exactly a concern, I just don't want to spend a great deal as this is already quite an expensive hobby overall. Plus, a fly press can be had for next to nothing I seems.
I'm not sure if I noted but I have tried the touchmark by hand and hammer with very inconsistent results. Some okay. Some very frustrating. The lettering I quite large and broad for a touchmark, so it's not really suited to hand and hammer, like a regular touchmaek with small and sharp lettering that bites in easily. I've trialed many times by hand, believe me, and just can't get good results. If I get the fly press and share a comparison which may help explain why I found this so difficult by hand (my own fault, really, I designed the touchmark).
