Angle grinder question
Home Forums Workshop Tools and Tooling Angle grinder question
  • #18416
    mick70
      @mick70
      mick70
        @mick70
        if nut on angle grinder is std right hand thread does that mean disc turns anti-clockwise?
        #284791
        Speedy Builder5
          @speedybuilder5
          Not on the 3 grinders that I have.
          #284794
            Depends if you are looking from the nut side or the top of the grinder.
            Anti clock looking from the nut side, clockwise from above
            Most have an arrow on the body somewhere to indicate direction
            #284797
            Mike Poole
              @mikepoole82104
              If you look at the nut side it goes anti-clockwise and from the gearbox side it will go clockwise, the nut should tend to tighten if you hold it still but I wouldn't use my fingers to test it. If you watch it coast down to stop it should be possible to see. When using the machine it will be obvious which way it is going. If your machine has been reversed it will be the nut that goes into orbit and the disc that chases you round the workshop. If you are outside then you will need a new nut and disc as you will probably never see either again.
              Edited By Mike Poole on 17/02/2017 19:38:54
              #284798
              not done it yet
                @notdoneityet
                Most of these machines have motors where the direction of rotation is not so easily reversed. Much like an automotive starter motor in that it does not care what polarity.
                They will work on DC current equally well as on AC, by the way – but I would prefer a 240V shock in preference to DC, I think!
                #284820
                Robbo
                  @robbo
                  Looking at the front of the grinder there is a left-hand and a right-hand wheel, and both turn "towards" you at the top.
                  Looking end on, the left-hand end has a left-hand nut and turns clockwise, the right-hand end has a right-hand nut and turns anticlockwise.
                  I remember a company that made woodcarving tools (Ashley Iles IIRC) used to specialise in rebuilding grinders so that they ran "the other way round" for the tool sharpening wheels they used (a rubber bonded wheel with embedded grit and a honing wheel). The motor wasn't reversed but the "bodywork" was rebuilt the wrong way round. The direction of turning was clearly indicated on the wheel guards or body. They used Rexon grinders. Carving tools are better sharpened with the wheel turning away from the tool.
                  #284824
                  Nicholas Farr
                    @nicholasfarr14254
                    Hi Robbo, all the angle grinders that I've ever seen only have one wheel/disc, which when you are using it rotates in a clockwise direction when viewed from the users normal point of view and have a right hand thread to hold the wheel in place. I think you must be talking about a two wheel bench grinder.
                    Regards Nick.
                    #284825
                    daveb
                      @daveb17630
                      If you hold the angle grinder as if you are cutting off a horizontal bar, the front of the wheel is moving downwards, the sparks are going away from you. The nut has a right hand thread, same as a the right hand wheel on bench grinder and for the same reason. Dave
                      #284827
                      Hacksaw
                        @hacksaw
                        Smith and Arrow 1mm cutting discs are directional , they have an direction arrow but the info on the disc then cant be read once its fitted , as the guard hides it…
                        #284833
                        Robbo
                          @robbo
                          Sorry, one of the other posts led me to believe this was about bench grinders
                          #284836
                          mick70
                            @mick70
                            thanks for replies.
                            all my grinders are in storage since lost workshop so couldn't look.
                            was looking at article in MEW about fitting drill chuck to bench grinder and brain started thinking about it.
                            #284838
                              Posted by naughtyboy on 18/02/2017 08:17:47:
                              thanks for replies.
                              dont know If you are thinking of fitting a drill chuch to an angle grinder
                              … Please reconsider.
                              The rotational speed is much higher than typical bench grinder.
                              Unless you could safely slow the machine right down [which is doubtful]
                              … it wpould be an 'an accident waiting to happen'.
                              Nigel McBurney 1
                                @nigelmcburney1
                                I fitted a jacobs chuck to an angle grinder so that I could drive the small diameter grinding points and bobs up to about a inch in diameter,does not work very well ,the chuck holds the small wire brushes tight ,the rattle effect on the sides of the grinding points soon loosens the chuck,,I was then given a windy drill with a collet which takes 1/4 and 6mm grinding points ,I soon gave this up as my compressor could not keep up with the drill,so the collet was adapted to fit the angle grinder and has worked well for the last 15 years,I used a 4 inch angle grinder as these run slightly faster than 4 1/2 inch grinders,it gets a a lot of usage when removing rust and debris from tight corners and crevices in old stationary engines.
                                #284846
                                  Noting Nigel's evidently successful practical experience …
                                  I shall refrain from further comment, and will follow the discussion from a safe distance.
                                  vintagengineer
                                    @vintagengineer
                                    I always thought there was two nuts on an angle grinder, one holding the grinding disc and one holding the grinder.
                                    #284853
                                    Martin Fijavz
                                      @martinfijavz60006
                                      The simple answer is yes. Angle grinder rotates in opposite direction as thread pitch. It is general rule for all nut clamped tooling.
                                      All universal motors can run in both direction (theoretically) – you need to change polarity of rotor, However most of the motors are designed only in one direction (to reduce wear brushes are placed out of the shaft axis ), opposite direction run will cause huge brush wear which will probably lead to failure.
                                      Only motors with brushes aligned with shaft axis can run in both direction.
                                      regards
                                      martin
                                      #284854
                                      mick70
                                        @mick70
                                        Posted by Michael Gilligan on 18/02/2017 09:02:02:
                                        thanks for replies.
                                        not planning on planning on it.
                                        was just one of those thoughts that pop into your about way something works thats all.
                                        #309847
                                        larry Phelan
                                          @larryphelan54019
                                          Reminds me of the time I went to ALDI,S to buy an angle grinder for a friend.While I was checking to see that the box was sealed,another old guy came drifting along,picking up everything,buying nothing [you,ve met them !]
                                          Picked up one of the boxes,opened it,pulled out all the bits and said"That looks a handy thing to have" I said,"it is,if you have the work for it" Next he said "I think I,ll buy one myself,what,s it for?"
                                          I could not believe my ears ! I said "if you dont know what it is,leave it alone,it,s not a toy".
                                          Maybe that,s why we need the H/SE !
                                          #309888
                                          Howard Lewis
                                            @howardlewis46836
                                            Larry
                                            Remember "Where ignorance is bliss, t'is folly to be wise"
                                            You should have asked for his name and address so that you can stay well away!
                                            Possibly related to the chap who suggested WELDING Imperial fittings on to continental bottles of Oxygen and Acetylene when bottles were in short supply in UK, some years ago! It really happened, in my employers company!
                                            Thankfully, he was dissuaded from doing this.
                                            #309900
                                            Ian S C
                                              @iansc
                                              I have seen chucks for angle grinders advetised here in NZ.
                                              Ian S C
                                              #309938
                                              larry Phelan
                                                @larryphelan54019
                                                what could a chuck be used for? a flexible shaft perhaps?
