All things Beaver Mill
Home Forums Manual machine tools All things Beaver Mill
Viewing 24 posts - 176 through 199 (of 199 total)
  • #658439
    Lex Davis
      @lexdavis38817
      Thanks for your reply Peter, there is an oil seal (item 40, Gaco Seal #MIS20) in the deep recess of the casting but it is not doing much in my case, the oil is definitely coming down through the spindle bearings, there is no leakage anywhere else. The sight glass is stained but still readable and until I can find an exact replacement it will have to stay there.
      Peter_H
        @peter_h
        You're right I missed that oil seal completely. I'm trying to think how else oil could get to the spindle bearings. The only openings I recall on the whole spindle assembly is the aperture at the top where the shaft comes out. Even with the quill at the lowest point, I can't see how, but it's difficult to think about the internals in 3D. I'll think on.
        Just so I'm on the right track, oil emerges from between the spindle and the quill, not from between the quill and the head casting?
        #658706
        Lex Davis
          @lexdavis38817
          Correct, it comes down through the spindle bearings, the outside of the quill is dry.
          #658717
          Mark Rand
            @markrand96270
            The good things are that you know the bearings are getting lubricated (even it it's not the grease they'd normally have) and that the last thing you want is a lot of 320 Weight gear oil between the quill and the head if they are still a good fit to each other.
            Consolation until you find the time and energy to strip the head and replace the seal!
            #660972
            Antony Harding
              @antonyharding74298
              Hi,
              For a Mk2 Beaver Mill is there a such a document that tells you the torque settings for the mill? If not how best to understand how much to tighten up nuts and bolts on the unit. Following my other posts have issues with runout on the spindle and before diving into the worrying task of taking out the spindle to see any issues just want to know I have all info needed to put it back together.
              Plus does anyone have a clear manual for a mk2 variable speed head? My one has the disk type breaking unit on the top, not the drum style. I have a couple downloaded from the internal but for the drums type break and can’t hardly read the part numbers.
              #678028
              Antony Harding
                @antonyharding74298
                Hi All,
                So, means of an update… with the spindle out I am still trying to find out my issue of the 0.9mm run out. While the spindle is on its side, I measured while rotating it on the outside face (photo AA tool end) and now only get 0.2mm run out. Then I measured at the same point NOT rotating it but trying to move the spine up and down and got no movement at all. Then I moved to the back of the spindle (photo BB nut end with locking washer) and done the same, about 0.3mm run out why rotating it and 0.2mm then moving it up and down. Lastly, I placed the indicator inside the INT40 cone and measured a run out of 0.5mm. Also rotating the spine, the bearings don’t sound the best, and you can see in photo CC the internal face of the INT40 cone is not looking its best.
                With my past submitted details on my issue and now the above would people believe my best course of action is:
                –          Remove the spindle from the spine to inspect the bearings and possibly replace them.
                –          Also, clean and, if anyone knows if you can do this hone /polish the inside of the INT40 cone to hopefully remove any imperfections.
                Fingers cross with the above I can have a workable Mill.
                Photo BBPhoto AAPhoto CC
                #678049
                  Not sure setting the DTI up like that helps much.  It assumes the outside of the spindle and the outside of the INT40 are round and concentric, which they may not be.   Run out only matters if it’s between the inside of the spindle and the inside of the INT40.
                  Replacing the bearings should be safe enough, and they are a likely cause.   I wouldn’t mess with the INT40 unless dead certain it was out of shape. I can’t see any imperfections bad enough to cause 0.3mm run-out.
                  As that’s huge, the cause must be something fairly gross – like badly worn bearings or a bent spindle.  Shine a torch on the far side of a straight edge laid lengthwise along the spindle and rotate it.  Light escaping under the edge should reveal if it’s bent.
                  Trouble with pre-loved gear is the history is unknown.  Possibly someone smacked a tool good and hard into something solid, destroying the tool and distorting the taper, spindle, and/or bearings.    In theory, heat and a hammer will fix a bent spindle.  In practice, I’ve never had to try.   Anyone else?
                  Diogenes
                    @diogenes
                    Now it’s out, it’d be best if you can snug the quill over some vee blocks on the mill table – this will give you a stable platform to work off and both hands free to manipulate things.
                    I think if you can establish the axial play (‘end float’) first and then the radial play, you will gain a better insight into where and how much things are moving which will then enable you to check concentricity with a more informed view of how the spindle can be / must not be handled to gain repeatable results that you can have confidence in.
                    As far as I can see from the pictures, the spindle assembly looks in ‘better than average’ condition for a machine of this size and age.
                    #679345
                    Antony Harding
                      @antonyharding74298
                      Thank Dave,
                      I will take the quill off to show the spindle and remove the bearings, and like @diogenes nots will set it up on the mill table, then as you suggest use a straight edge to see if the spindle is ok.
                      Yep them bearings are a costly item of £300 but if this is my issue, why painful in cost happy days if this is the issue.
                      Have you ever had to change bearings on a Spindle? what’s the best way to get them off and on? Can believe is a very snug fit.
                      #679347
                      Antony Harding
                        @antonyharding74298
                        Hi @diogenes,
                        Thanks for your message… While on blocks on my workbench, end play of the spindle in the quill (in and out) was 0.0mm on the DTI. But like to say will buy some V Blocks and try this on the mill bed. Following my message above and being new to machining need to find a way to make this bad situation turn into a usable machine. Its a lovely mill as a unit and don’t want to scrap it. Just hope the spindle is straight and maybe its the bearings?
                        As a side note would you know how best to polish off the small amount of dirt/rust i have on the quill and inside the INT40 spindle?
                        #679464
                        DC31k
                          @dc31k
                          A few of these with the appropriate non-embedding abrasive on them followed by a proper clean:
                          #684532
                          Antony Harding
                            @antonyharding74298
                            Afternoon All,
                            Following my past issues with my spindle I found the courage to breakdown the quill from the spindle to inspect the bearings and was very surprised to see it had only two bearings. The Manuals notes there should be three. Has anyone seen this type of spindle before with only two bearings? The marks on both bearings are (32008c SNR France).
                            IMG_5460IMG_5461IMG_5474
                            #684639
                            DC31k
                              @dc31k
                              Is the exploded diagram in the manual you have specifically for the 40 taper spindle?
                              It is true that the 30 taper spindle has three bearings, but the design may have changed for the 40 taper option.
                              What manuals exist for the Beaver are not comprehensive in the sense that not every option Balding offered made it onto paper.
                              SNR is now part of NTN, but the bearing designation is a standard taper roller one. If replacing, it would be wise to talk to a bearing specialist to find out what precision level or class they would recommend for a spindle application.
                              #685609
                              Antony Harding
                                @antonyharding74298
                                Thanks, below is the diagram that I have (if anyone has a diagram for the 40 taper that would be great).
                                Could anyone recommend a bearing specialist they have used in the past? Being that the 30 taper uses Hoffmann bearings, would like to see if I can get Hoffmann bearings for my spindle, as I believe from reading, Hoffmann and German precision bearings ???? Plus not sure if the bearings in the spindle now are the original ones anyway.
                                Spindle
                                #685634
                                Mark Rand
                                  @markrand96270
                                  My Mk1 VBRP had obviously had one or more serious crashes in past lives and the spindle was, indeed, bent. More at the top than the bottom. Supporting it on V blocks, U mapped the bend using a DTI, then moved the supports to appropriate locations and straightened it with a block of brass and a soft hammer. No great difficulty.
                                  Afternoon All,
                                  The 40 NMTB spindle arrangement was significantly different from the 30 NMTB one. This was necessary because the quill diameter wasn’t changed and that was sized for the 30 taper spindles. Hence the taper roller bearings, which take less space than angular contact ball bearings.
                                  It’s not easy to tell from your photo, might just be grease on the outer race and rollers. After cleaning, if they aren’t all shiny and spotless, with no flats or grooves, then it’s new bearing time.
                                  #711413
                                  Antony Harding
                                    @antonyharding74298
                                    Hi All,
                                    Can anyone help me to understand why I can’t pull down the locking pin enough to enable the spindle (turning the handle) to come done? It moves down halfway but no further.2024-02-02 19_07_56-Window
                                    #734563
                                    roryd
                                      @roryd
                                      Morning All,
                                      I’m trying to get the speed controls working for a Beavermill 5.
                                      The head motor runs fine as well as its hydraulic and pneumatic elements of speed control and mechanically the machine is largely sound.
                                      The X, Y and Z axis on this particular model have electronic control, via a small pair of rotary selectors the the left of the head, along with start button, speed control pot, tuning pot, indicator light, and quick traverse function. The top selector selects between “rev”, “off” and “for” and the bottom selector select “X”, “Y” or “Z” axis.
                                      Control is via a Quinton Crane Electronics Derby speed control board, in the lower LH cabinet on the main machine.
                                      The photo’s show one of the axis motors and the speed control board.
                                      Anyone else with this setup? Any schematics or diagrams for this setup available? Thanks Rory
                                      IMG_2420IMG_2421
                                      #790537
                                      scud106
                                        @scud106
                                        Hi all
                                        i have a beaver vrpb mill ( mk1 I think) and I have stripped the spindle to replace the bearings and quill n head for maintenance. The lower bearing didn’t have grease in them however to top one was packed. I was wondering if the lower bearing should packed with a soft grease before installation or just oiled. Are the brass greasers/ oilers on the side of the quill for grease if so should the quill be then packed with grease or are they oilers which would just have a daily squirt.
                                        would any one know a preload for the bearing or is just a touchy feely u til the feel right.
                                        any information would be greatly appreciated.
                                        #795288
                                        Mark Guy
                                          @markguy26995
                                          Hi all.
                                          just giving the old beaver a spouse up I’ve fitted be spindle bearings ( even managed to find a set of genuine Hoffman bearings) I’m currently working in the bed and lead screw.
                                          I have 3 questions.
                                          1:- has any one tried fitting 3 lower bearing to the spindle like the modification done to the bridge ports to improve spindle stability.
                                          2:- I’m thinking of surface grinding the Gibs as the bed gets tight on either end of the table when I adjust the play in the bed to suit the center and just wondering weather this may make it better or worse.
                                          I’ve not measured the dove tails as yet as I need a lift with it.  2:- on the right side of the bed where the lead screw handle is when I remove the lead screw handle carrier which mounts to the bed there is a machined inset which looks like it could take a 2”x 1” x 1/2 bearing and was wondering if it should have one but I can not see one listed in the parts book ( but my book I think is for a mk2).
                                          I would appreciate any suggestions
                                          #795291
                                          Mark Guy
                                            @markguy26995
                                            IMG_2813
                                            #795295
                                            Mark Guy
                                              @markguy26995
                                              Ahh one other thing.
                                              does any one know how to adjust the clutch on the auto feed on the spindle.
                                              #795298
                                              Mark Guy
                                                @markguy26995
                                                IMG_2816
                                                #798284
                                                Mark Rand
                                                  @markrand96270
                                                  Sorry for the very late reply. Blame life, the universe and everything…
                                                  Your questions in order:-
                                                  1. I doubt whether adding an additional bearing at the bottom of the quill and spindle would do anything useful to improve the rigidity of the spindle. The spacing between the bearings gives the stiffness. One could, measure the heights of the spacer sleeves between the bearings and calculate the bearing preloads, if one had the required data from the bearing manufacturer and then surface grind one of them to get the best preload.
                                                  2. Surface grinding the two table gibs won’t give any improvement in the friction from the middle to the end of travel. That’s a function of the flatness of the horizontal table ways and the parallelism of the table dovetail ways. If you can find someone with a Churchill or similar, way grinder you can sub the job out. Failing that, you’re into scraping the ways. Note that the top of the table will be ‘hogged’ unless the machine had been treated with kid gloves for its entire working life. This is mainly caused by peening the undersides of the T-slots when clamping work and vices, which expands the top and causes the table to hog. As a datum, I scraped 1lb of metal from my 48″ table when I rebuild the machine :O .
                                                  3. The end plate on the right side of the table was made from the same casting as the left hand one. The feedscrew thrust bearings are in the left hand one and the right hand one is a sliding fit. if you constrained it, the table might sag and hog with temperature differentials between feedscrew and table.
                                                  4. To adjust the auto-feed clutch, take the round side cover off the left hand side of the clutch lever and prise off the E-clip that retains the lever (carefully, they like to travel to hideyholes in far parts of your shed). get the lever out of the way and pull out the clutch assembly. Bore a hole in a plate of aluminium/brass/steel to fit the bottom/inner part of the assembly. Split the plate with a saw to make it into a clamp. Loosen/remove the clamping screw on the split nut at the outboard end of the clutch assembly (if there. That seems to be a detail that changed during production). Clamp the assembly with it into a vice and turn the nut clockwise to tighten and vice-versa. You may want to completely strip it down and clean/re-grease everything. Mine was seized solid. Note that you might need to readjust it a time or two to get the right setting. The feed shouldn’t have any trouble with a 1/2″ drill in mild steel. It’s a good idea to have an aluminium or brass taper pin in the worm that feeds the auto-feed. That’ll protect the gears.
                                                  Hope that helps.
                                                  Mark Rand
                                                  #802393
                                                  joshhansen1987
                                                    @joshhansen1987
                                                    Hello all. I recently bought a Beaver VBRP mk2 with a variable speed head and while cleaning it up I noticed some strange things with the speed control knob. I ordered a manual and started going through the parts list and found that the entire rocker arm assembly to move the front pulley up and down was missing.. if anyone could tell me where I can buy those parts, or have those parts I would love to purchase them from you because as it stands right now I essentially just bought a 2 speed drill press. Any help on the matter would be greatly appreciated. Thank you
                                                    -Josh
