Airline connectors anyone?, – Biax grinder
Home › Forums › Workshop Tools and Tooling › Airline connectors anyone?, – Biax grinder
  • #297571
    capnahab
      @capnahab
      img_9983.jpgAnother ebay find. My workshop air (and knowledge) does not extend beyond a few PCL connected tools. My compressor has a line with a vertex PCL (female) connector and most of my tools have PCL male ends. I would like to get this grinder working in much the same way. I think a short 'flying' hose to the grinder would be good.
      I don't know what sort of connector is currently on it ?, can anyone identify it?. I could then get a female end to connect onto the flying lead, PCL at the other end.
      Also , I could do without all the added bulk of the steel exhaust at the other end. does anyone know Biax ?, is there an alternative that is a bit more user friendly ?img_9982.jpg
      #18515
      capnahab
        @capnahab
        #297690
        David George 1
          @davidgeorge1
          Biax is a German air tool manufacturer who make high end air tooling. The connector isn't one I have seen before should unscrew to fit PCL fitting. Look up biax-Germany.com/eng
          David
          #297692
          Jelly
            @jelly
            BOSTICH use those connectors too, I’ve always just unscrewed them and installed a standard fitting (2.99 for a pair at toolstation last time I needed some).
            #297753
            Ian S C
              @iansc
              The last time I needed a male fitting, i ended up making my own, seems to work ok.
              Ian S C
              #297768
              Chris Shelton
                @chrisshelton11794
                Hi, I think they are called euro connectors, ebay item No.
                252780579939
                HTH
