Hi, I meant the tops of the threads seem equal in width and not narrower on the middle of the screw where In assume most wear takes place.Whereas the nut threads look more pointed on the crests. I must admit I have also assumed that the leadscrew will be an acme thread, it is 3/8" diameter and 10 tpi and the lathe seems to be a myford ML7 clone. Nevertheless thanks for the heads up, measure twice, cut once………., but I keep getting it backwards!
Paul
Edited By Paul Barter on 17/02/2017 20:36:21
