Acetal or phosphur bronze
Home Forums General Questions Acetal or phosphur bronze
  • #457660
    Steviegtr
      @steviegtr
      The cross slide on my S7B has a bit of axial play behind the Vernier gauge. It is an alloy casting the cross slide screw goes through , with the Vernier scale outside of it, with finally the winding handle. The play is in the casting of the alloy frame. Side to side which is annoying when winding the slide back & forth it chatters.
      I have had it in bits & the screw & shaft seem unworn. But the alloy has a slight oval to it. Rather than buy a new casting nose piece, I thought of making a bronze bush for it. Then I thought I have lots of Acetal/ Delrin bar. It seems good enough for the gears on some Chinese lathes , so is it good enough to make a small sleeve bush out of. I would need to bore the casting out to accept the bush but at least it would get rid of the annoying side play. Anyone done this or similar.
      Steve.
      Steviegtr
        @steviegtr
        Cross slide
        #457667
        John Olsen
          @johnolsen79199
          Acetal would be fine in this sort of service, or you could consider going the whole hog and doing the mod on the Arc Euro site:
          Arc Euro thrust bearing mod
          regards
          Ady1
            @ady1
            Delrin doesn't last long
            As a quick fix I've found aluminium good
            Pbronze is bestest
            #457669
            Steviegtr
              @steviegtr
              Posted by John Olsen on 17/03/2020 00:00:46:
              regards
              Shame that is only for the ML & not the super 7. But given me an idea seeing that.
              steve.
              #457670
              Steviegtr
                @steviegtr
                Posted by Ady1 on 17/03/2020 00:02:20:
                Pbronze is bestest
                That does surprise me. A lot of the Chinese mini lathes have the gears made from Delrin. I am not talking about nylon.
                Steve.
                #457671
                Ady1
                  @ady1
                  Same with leadscrew nuts
                  Delrin lasts a few months then fails
                  …or you could white metal it…what do they call it? Babbit devil
                  Edited By Ady1 on 17/03/2020 00:30:57
                  #457673
                  Steviegtr
                    @steviegtr
                    I do have some aluminium that would do the job & just as easy to work with. Got me thinking now. Anyway seems since we have decided not to go to our motorcycle café meeting 3 times a week for the foreseeable future, I will have plenty of time to do all the jobs on the list.
                    steve.
                    #457675
                    not done it yet
                      @notdoneityet
                      Ady1,
                      What pitch and diameter were these? Are these for lead, or feed, screws? I made an acetal feed screw nut but have never needed to fit it. I would expect/hope it to last better than for a lead screw. It is very tight, with zero backlash, so needs easing off a bit, methinks.
                      #457678
                      Steviegtr
                        @steviegtr
                        Posted by not done it yet on 17/03/2020 01:00:57:
                        Ady1,
                        I am not thinking of making leadscrew nuts, just a simple bush. I cannot see how it would wear out quickly as it has no axial loads on it or any angle loads, it is just a simple guide. The only load is a the operator turning a handle.
                        Steve.
                        #457688
                        HOWARDT
                          @howardt
                          It is worth giving it a go. The bearing is just a support, load on the bearing depends on the size of the hand wheel and the force you use to overcome friction and cutting forces. Nothing lost when it fails again, then use a leaded bronze.
                          #457700
                          Ady1
                            @ady1
                            Drummond M leadscrew lasted a week or two, I made a full wrap nut, Drum M cross slide nut lasted a month or two, I was a heavy daily user at the time, 2-3 hours
                            As you say, lovely and tight, with zero backlash, feels brill to start with
                            but alas doesn't last
                            Aluminium has been brill with good longevity
                            I was burning through original M series leadscrew half nuts at a rate of about two a year (they used a very soft bronze) and wanted something more reliable to use for spare parts
                            Edited By Ady1 on 17/03/2020 09:26:29
                            #457704
                            Pete Rimmer
                              @peterimmer30576
                              Stevie, it's not a vernier scale, it's a cross slide dial. Might seem like a minor thing to pick up on but a vernier has two opposing scales.
                              As for the bush, you could make one from acetal and it would last a good while so long as the shaft has an excellent finish on it. Also be aware that holes drilled and reamed in acetal tend to come out tight.
                              #457733
                              Steviegtr
                                @steviegtr
                                Posted by Pete Rimmer on 17/03/2020 09:59:05:
                                I've been told off before talking about Vernier & the word digital. Haha. Never mind it has marks around it in thou's how's that. Now I have had some replies, maybe today it's time to take it off again to see how robust the casting is etc. Thanks for the tips.
                                Steve.
                                #457736
                                not done it yet
                                  @notdoneityet
                                  Thanks, Ady 1. I’ve repaired a nut with a brass bush since. 1/2” diameter 8 or 10 tpi square thread. The acetal one was made by the “heat and squeeze method”.
                                  #457755
                                  Nigel McBurney 1
                                    @nigelmcburney1
                                    Leaded bronze is better than phosphor bronze and easier to macine
                                    #457761
                                    Steviegtr
                                      @steviegtr
                                      Well that was a quick fix. There is a screw under the casting at the bush. Not a bush but where the shaft runs through the alloy casting. Not sure what it is for.
                                      Removed it, drilled a 3mm hole up the centre. Then a made a little pad using a piece of 3mm brazing rod, which slid inside the screw. The protruding end , I burred over to create a pad. Fit it back together & it worked. No more side play. Cost, nothing.
                                      Steve.
                                      #457782
                                      KWIL
                                        @kwil
                                        On a S7B with Power Cross Feed the small threaded hole under the casting is for a small pin which impacts with the PCF on/off knob, so that it is not possible to continue to drive the cross table beyond the inner limit.
                                        Without this item, breakage will undoubtably occur.
                                        Edited By KWIL on 17/03/2020 15:53:35
                                        #457792
                                        Steviegtr
                                          @steviegtr
                                          Well you learn something every day. I wondered what on earth it was stuck there doing nothing.
                                          Steve.
                                          #457863
                                          KWIL
                                            @kwil
                                            My Myford S7s have had their front brackets modified with a PB bearing and needle thrust washers, not a difficult thing to do.
                                            #457886
                                            not done it yet
                                              @notdoneityet
                                              Posted by KWIL on 17/03/2020 15:53:09:
                                              A point where the myford is better than the Raglan? Outside towards centre is no problem facing, as the screw would wind itself out of the nut eventually (I would have to be asleep?) but in the other direction it could be trouble.
                                              I (nearly) always face from outside to centre but have to be careful when parting-off, under power, with the rear tool post.
                                              #457901
                                              Pete Rimmer
                                                @peterimmer30576
                                                Posted by Steviegtr on 17/03/2020 14:21:37:
                                                Steve.
                                                Not so much a repair as a bodge, but if you're happy with it then no-one else needs to be.
                                                #457902
                                                Hopper
                                                  @hopper
                                                  Steve.
                                                  You could have got the same result by burring over the edge of the oval-shaped hole in the casting with your hammer.
                                                  #457947
                                                  Steviegtr
                                                    @steviegtr
                                                    Point taken. It is only a temp fix till I can get the bearings for the job to be done properly. At least it has stopped the rattle. for now.
                                                    Steve.
