AA batteries
AA batteries
Home › Forums › General Questions › AA batteries
Viewing 21 posts - 1 through 21 (of 21 total)
  • #28275
    Clive Hartland
      @clivehartland94829
      #555887
      Clive Hartland
        @clivehartland94829
        I recently bought some AA batteries, a box of 40.
        Needing to change the batteries in the house fone I tipped out the old ones and inserted the new fresh ones but found that the + contact did not reache the contact in the battery holder.
        I am convinced that the new batteries + end is shorter than it should be.
        I will now have to commit surgery on the battery box to cut away part of it to allow full contact.
        The batteries came from a reputable supplier.
        #555888
        Grindstone Cowboy
          @grindstonecowboy
          I've been finding this more and more recently – but I also think the length of the cells is increasing as they appear to be harder to fit into the available space. Duracell seem to be the major culprits, but I've also noticed that Panasonic Eneloop rechargeables are bigger than the traditional cells. Things like Nikon Speedlights seem to have enough latitude built-in to cope, but older TV remotes are definitely on the lower end of the tolerances.
          Rob
          #555893
            Energizer quotes “industry standard” dimensions : **LINK**
            https://data.energizer.com/pdfs/l91.pdf
            I would be interesting to know how yours compare
            AJAX
              @ajax
              Posted by Clive Hartland on 26/07/2021 22:00:37:
              Was that a BT cordless phone by any chance? I had exactly the same problem when I changed batteries but when I prised the spring clips out a bit it was enough to make good contact. Alternatively I could have bought the BT approved/branded replacements instead at an inflated price.
              Update – my phone uses AAA and not AA batteries.
              #555897
              Grindstone Cowboy
                @grindstonecowboy
                Some rough measurements using digital calipers
                Duracell AA cell Panasonic Eneloop
                Diam 13.91 to 14.30 (not truly circular) 14.18 to 14.45
                Overall length 50.67 50.43
                Main body length 48.80 49.17
                Pos terminal 1.88 1.30
                The plastic sleeve makes accuracy difficult as you get difference depending where exactly you measure, but the above are as close as I could get. Also had to be quick as the caliper were effectively shorting out the cell on a couple of the measurements.
                So it seems they are both within spec apart from the diameter of the Duracell in certain orientations.
                I'll try a few others.
                Rob
                Edit – Drat! The careful formatting didn't work – first figures are Duracell, second are Eneloop
                Edited By Grindstone Cowboy on 26/07/2021 23:12:34
                #555901
                noel shelley
                  @noelshelley55608
                  A dab of solder on the contact should work ! Noel.
                  #555903
                  Bazyle
                    @bazyle
                    Scrunched up heavy tinfoil eg from pie case.
                    #555921
                    J Hancock
                      @jhancock95746
                      Yes, exactly same problem , the cap end would not reach the contact plate in the can opener.
                      Soldered a 'blob' onto the contact plates , fits all batteries now.
                      #555927
                      Macolm
                        @macolm
                        Another thing to watch is projection of the plastic sleeve at the negative end. Intemittent problems with replacement AAA rechargables in out Panasonic phones were due to poor contact due to this. They are now fine after trimming flush with a razer blade.
                        #555930
                        Nick Clarke 3
                          @nickclarke3
                          Naming an offender IKEA yellow AA batteries will not work in my Worcester Bosch wireless central heating controller for just this reason
                          #555939
                          Oily Rag
                            @oilyrag
                            And I thought this was a thread about Flak Batteries from WWII !!!!
                            #555970
                            Vic
                              @vic
                              Posted by Oily Rag on 27/07/2021 09:56:35:
                              laugh Good one!
                              #555979
                              Clive Hartland
                                @clivehartland94829
                                Hi AJAX, no, not a cordless fone,just a house fone with answerfone.
                                This is not the only item I have found with battery insert problems and to my mind the makers have changed the
                                design slightly.
                                Answers show it is a problem for people.
                                #555981
                                bernard towers
                                  @bernardtowers37738
                                  I thought it was more that the battery boxes in stuff made in you know where are a bit scant on dims. American stuff that takes batts is ok, or mine is!!
                                  #555983
                                  Peter Spink
                                    @peterspink21088
                                    Posted by Grindstone Cowboy on 26/07/2021 23:11:22:
                                    Some rough measurements using digital calipers . . .
                                    Do you now have lots of flat batteries? devil
                                    #556002
                                    roy entwistle
                                      @royentwistle24699
                                      Anyone measuring batteries with calipers, insert a piece of writing paper between one end of battery and caliper,
                                      then measure thickness of paper. deduct paper thickness from battery length.
                                      This is not meant to be patronising in any way
                                      I have found some batteries that vary in the same pack
                                      Edited By roy entwistle on 27/07/2021 15:58:58
                                      #556005
                                      Oven Man
                                        @ovenman
                                        Posted by roy entwistle on 27/07/2021 15:54:46:
                                        This is where a cheapo plastic vernier caliper comes in really useful.
                                        Peter
                                        #556007
                                        Oldiron
                                          @oldiron
                                          Posted by Peter Spink on 27/07/2021 13:58:59:
                                          exactly what I was thinking. devil
                                          regards
                                          #556014
                                          Grindstone Cowboy
                                            @grindstonecowboy
                                            Posted by Oldiron on 27/07/2021 16:58:38:
                                            regards
                                            Not flat, but one got a little warm blush
                                            #556089
                                            Anonymous
                                              … or just zero the calipers with the paper in.
