1) I always thought BSP stood for British steel pipe but apparently it is British standard pipe – Is that correct?
2) I always thought BSP threaded items had a tapered thread but it seems that they are parallel & if I want tapered it is BSPT
3) I thought one could put a tapered thread to a tapered thread male to female. Apparently not so. Hence female to female straight connectors are parallel threads& the male part going in are the tapered part only. Is that correct?
Can someone enlighten me please because it is 45 years since I had any dealings with steel water pipe & my memory is a blank.
Someone cannot make a joint between 2 male pipe ends ( parallel) with a straight piece & i noted it is parallel threads to parallel threads & suggested a tapered thread straight connector ( Female/female) & was told not made cannot be done. I even suggested if they could not get straight connector use a "T" & stick a tapered plug in the spare end. Once again i was told to go away
It is on a water tank in a boat
Is that right or wrong, Have I totally lost my marbles.
Edited By Sam Longley 1 on 05/05/2016 14:02:22
Edited By Sam Longley 1 on 05/05/2016 14:03:44
