A rogue thread on my Myford saddle?
Home › Forums › Manual machine tools › A rogue thread on my Myford saddle?
  • #306705
    choochoo_baloo
      @choochoo_baloo
      Hello all. Can someone tell me a) the thread & b) it's use, on the rear leg of my Myford ML7 saddle. For comparison I've placed an old style oil nipple next to it – clearly isn't 2BA.
      I don't have any 1/4" bolts to hand, but Mike's offerings at lathe spares, made me test a 1/4" BSF tap into the threads. The 1/4" does seem right……assuming it is a 1/4" then why is mine threaded?
      The aim is to place a nipple, http://www.lathespares.co.uk/myford-oil-nipple-raised-1-4 there. As there is currently no oiling point for the rear bed shear.
      Thanks in advance.
      #13003
      choochoo_baloo
        @choochoo_baloo
        #306707
        alan-lloyd
          @alan-lloyd
          Hi, Could it be for mounting the bracket for the coolant gubbings?
          #306709
          Robbo
            @robbo
            Posted by alan lloyd 3 on 11/07/2017 18:51:51:
            That's it in one smiley
            But there is an oil nipple for the rear shear – wind the cross-slide out and you will see it.
            Edited By Robbo on 11/07/2017 18:57:55
            #306711
            choochoo_baloo
              @choochoo_baloo
              Ah ok that figures thanks; as in that extending nozzle thing that I've seen on some Super 7 s?
              In which case why is there no top shear nipple like for the front shear?
              #306726
              Robbo
                @robbo
                "In which case why is there no top shear nipple like for the front shear?"
                Because there is no room where it ought to go, because of the saddle lock, so its on the rear of the saddle with grooves in the underside of the saddle for the oil to run along. And right awkward to get at.
                #306737
                Nick Taylor 2
                  @nicktaylor2
                  Off the top of my head I think it's M6 on my lathe (1974 vintage).
                  Regarding the oiling of the rear shear – are you aware of the oiler on the back face? Put a good whallop of oil in that and it should coat the rear shear fine.
                  Edited By Nick Taylor 2 on 11/07/2017 20:10:58
