A cheeky/optimistic request – 7/8 20 tpi die?
Home › Forums › General Questions › A cheeky/optimistic request – 7/8 20 tpi die?
  • #316833
    Symon
      @symon78657
      This is a bit cheeky considering none of you know me yet…but…I need a 7/8" 20tpi die (BSB?) to repair the thread on a shaft of my mill restoration. Tracy Tools have the taps and dies but I can't really afford to buy them for just one quick job.
      Would any of you guys have one I could borrow? embarrassedObviously I'd cover the postage costs (both ways) and love you forever heart
      Sorry about the sheer nerve…but I'm a wee bit desperate.
      #25496
      Symon
        @symon78657
        #316843
        Chris Evans 6
          @chrisevans6
          I will look in my workshop tomorrow, I do have a selection of odd ball stuff. Will PM if I find one.
          #316844
          Symon
            @symon78657
            That's greatly appreciated, Chris beer
            #316847
            not done it yet
              @notdoneityet
              Do you really need a die or would a thread chaser be sufficient? A location might help, too. There might be someone local.
              #316848
              John Rudd
                @johnrudd16576
                Posted by not done it yet on 13/09/2017 16:39:15:
                His intro thread gives his location as Newcastle/Durham……oop north then….
                #316849
                Symon
                  @symon78657
                  Ordinarily a thread chaser would probably do. But there's a part on the thread where an old pin is and that's stuck tight. So it'll need cut through. Also it's on the machine already which means no more bashing to get the pin out.
                  I'm in the North East between Durham and Newcastle.
                  #316851
                  Symon
                    @symon78657
                    OP should be read BSC (British Standard Cycle).
                    #316866
                    David Standing 1
                      @davidstanding1
                      Posted by Symon on 13/09/2017 17:04:23:
                      Are you sure? I work on old cycles with BSC threads a lot, and 7/8" should be 24 tpi.
                      7/8 x 20 is however a UNEF size.
                      Edited By David Standing 1 on 13/09/2017 18:36:47
                      #316867
                      Clive Brown 1
                        @clivebrown1
                        Tracey Tools refer to 7/8" x 20 as cycle thread, presumably where the OP is coming from.
                        if the pin area is the only problem, I wonder whether a small triangular file could be used to dress out the remains of the pin. The thread angle seems likely to be 60 deg.
                        #316870
                        Symon
                          @symon78657
                          Yeh, TT calls it BSC: **LINK**
                          The threads measure 20tpi on my cheapo gauge, which I don't really trust…but it is.
                          The threads are just rounded a bit, not crossed, and I'll likely flatten the pin area to accept a grub screw instead of the original pin.
                          #316872
                          Symon
                            @symon78657
                            Would it not be weird to have a unf/unef thread on a late 50s UK machine which uses Whitworth for the most part?
                            #316874
                            David Standing 1
                              @davidstanding1
                              Posted by Clive Brown 1 on 13/09/2017 18:46:37:
                              Yes, that's odd – Tracy Tools show two BSC pitches, 20 tpi and 26 tpi. All the cycles I have worked on are 26 tpi, 20 tpi is a new one on me!
                              #316875
                              David Standing 1
                                @davidstanding1
                                Posted by Symon on 13/09/2017 19:00:06:
                                If it is a British machine, yes! smiley
                                #316881
                                Symon
                                  @symon78657
                                  Exactly. This thing has some weird threads, though. The pipework uses 26 tpi BSC which I had a friend tap an oil part as like now…I really didn't want to buy a use once part laugh. BSP was well in use at the time of manufacture, and it even uses BSP in places! Ha!
                                  #316882
                                  John Stevenson 1
                                    @johnstevenson1
                                    Posted by David Standing 1 on 13/09/2017 19:03:26:
                                    Once you get above a certain size you get an alternative of 20 from the normal 26. Pedal threads have always been 9/16" x 20 RH and LH
                                    Chances are that I do have one, I have a full set up to 1" in RH and LH threads but I can't check as I'm off work for a while.
                                    Can you use a thread file or at worst a small triangular file
                                    #316883
                                    Symon
                                      @symon78657
                                      Still, it's looking beautiful, so can't be mad with it.
                                      #316884
                                      Symon
                                        @symon78657
                                        No thread file atm. But I could always borrow one. Would rather clean it up with a die.
                                        #316947
                                        JohnF
                                          @johnf59703
                                          Symon see your messages
                                          #316951
                                          Symon
                                            @symon78657
                                            yes
