¾” 4TPI lead screw nut
Home › Forums › Materials › ¾” 4TPI lead screw nut
  • #410599
    simon Hewitt 1
      @simonhewitt1
      Does anyone know where I could get a ¾" 4TPI lead screw nut? Outside dimensions not important, its to fit an old pillar drill, the table lift is by lead screw and it has stripped out the thread in the table carrier. Thanks
      Simon
      #29919
      simon Hewitt 1
        @simonhewitt1
        #410676
        John Reese
          @johnreese12848
          It is possible to single point a 3/4-4 thread. I used either a 5/8" or 1/2" boring bar with a very short tool bit. There was not sufficient clearance to withdraw the tool from the hole. I had to back off the cross slide a few thou and wind the tool out of work. I did it on a 13" lathe and it took many, many spring passes to finish the thread. I am not sure how well a smaller, less rigid lathe would handle the job.
          #410691
          Chris Evans 6
            @chrisevans6
            Have you looked at the prices from the lead screw suppliers? It may be quicker and cost effective to buy a length of lead screw and a nut, for rise and fall does the pitch matter ? I did my lathe cross slide for sub £50 and have enough screw for three replacements. Consider going trapezoidal/metric it can be cheaper.
            #410815
            simon Hewitt 1
              @simonhewitt1
              Thanks Chris Evans – I think I will go this route. The screw is almost exactly 1 M long, and as you say, pitch is not critical, it just has two bevel gears and a winding handle. I am tempted to go for a ball screw and lead, and an electric motor, with an up/down switch, just for fun. Also I am not certain it is an Acme thread, looks like a square thread, but its difficult to see clearly until I pull it out. And it weighs a lot!, must be > 150kg.
              #411705
              Zane Crowther
                @zanecrowther67531
                Hi,
                There are lots of trapezoidal screws and corresponding nuts online. Maybe have a look at these: **LINK**
                Zane
                #411840
                  Posted by simon Hewitt 1 on 24/05/2019 20:27:53:
                  Presumably this is the drill pictured in your Album, and nicely illustrated here: **LINK**
                  http://lathes.co.uk/denbigh-drills-page2/
                  … If so, I am sure you are thinking along the right lines yes
                  simon Hewitt 1
                    @simonhewitt1
                    What a great illustration. Mine is newer than that with the motor behind the column and modern style multi-sized V pulley, but the main column and the table adjust are exactly the same.
                    Chinese balls screws are remarkably cheap and I have a windscreen washer motor that will probably do, I will post a photo when complete.
                    #411864
                    simon Hewitt 1
                      @simonhewitt1
                      In fact, looking at the lathes site, mine is the K.1.A series 2 on page 2 here
                    Home › Forums › Materials › Topics
