Reply To: A very small Shaping Machine …
Home Forums Manual machine tools A very small Shaping Machine … Reply To: A very small Shaping Machine …
#133609
IanT
    @iant
    "Bunyons" (or something similar). Just hit the wrong button and lost the reply I have taken some time to type in!
    Let's try again.
    With regards to the recent posts above, I'm not too sure how the (ram) tool would sweep in a horizontal arc as it cut (if that is what is being suggested above) but a 'rotating' hand tool held over the work by the (static) ram might? (Does this sound too much like a milling machine??) I would certainly like to know more about your idea though.
    Of course, there are shaper heads that allow the tool to be swung in a vertical arc (with the ram static) enabling circular cavities to be shaped and it's also quite possible to 'profile' shape (but not easy I can assure you). There are also "diving heads" (for want of a better description) that enable the work to be turned as it is shaped. A variation of this enables involute gears to be cut (the work is rotated a fixed amount as the table moves sideways – this happening as the ram moves backwards for the next cut). But I don't think this is what is being suggested – so I'm somewhat puzzled but also curious.
    Going back to "a very small shaping machine" Michael – I have a slightly different approach for you. I am of course heavily influenced by the fact I already have an Adept No 2. Mine is probably coming inside this winter (to join my other small modelling tools) and I have been thinking along the following lines.
    I will make a sub-table to fit the existing Adept table – but it will have a series of accurately spaced tapped holes to enable a flexible clamping approach. I will equip this base with several devices (possibly loaned from other machines) such as a compound slide and 3" rotary table both of which can also hold/clamp small parts (so an ER16 faceplate on the rotary table for instance). I will also make a range of small cutting tools (including saws and files) to fit the existing tool head. I will therefore retain the (relatively) massive rigidity of the No2 but gain (I hope) a good deal of finesse in terms of work movement & measurement. Perhaps I should also mention that the No 2 has a base footprint of about 7" x 8" ( and I can pick it up without too much effort if required) so it's not a massive machine in that sense. It's also very quiet in use if course.
    By the way – if I needed to cut semi-arcs on the (hand) shaper (and I would most likely use the Taig for this) I could fix the ram (X & Y) and use a 'free' rotary table to swing the work, just putting the cut on with the head. But I don't think that was being suggested above either?
    Anyway, my suggestion (in a nutshell) Michael, is to not completely ignore the larger (hand) shapers but to perhaps think more in terms of finding other ways to move the work under the ram/tool of the larger machine with the degree of finesse that you require. Just a thought.
    IanT
    Edited By IanT on 25/10/2013 11:35:08
