Drilling a parallel 1/2″ hole
Home Forums Beginners questions Drilling a parallel 1/2″ hole
  • #287805
    Peter Simpson 1
      @petersimpson1
      I was pottering about in the workshop today and decided to make a tail stock die holder.
      I mounted a 11/2" diameter piece of EN8 steel in a four jaw chuck and set it up to 1 thou TIR.
      Faced the end off.
      Centre drilled the end.
      Drilled it through with several pilot drills.
      Drilled it to 1/64th of full size.
      Reamed it to Full size if 1/2".
      Now the problem, If I spin the finished item on it's central axis, The end that had been away from the Tailstock has a 8 thou run out, should I have drilled it from both ends prior to putting the reamer through it. ?
      #8606
      Peter Simpson 1
        @petersimpson1
        #287815
        HOWARDT
          @howardt
          How long was the hole. Better to use 3 or 4 flute core drills to open holes out as 2 flute will wander.
          #287820
          Peter Simpson 1
            @petersimpson1
            The hole was nearly 3" long.
            #287833
            Spurry
              @spurry
              Not sure from your description if the 3" piece was internal to the chuck jaws or outside. If outside the jaws, your error would suggest that you did not clock both ends of the visible piece.
              You could make a mandrel on which to mount your 3" piece, then turn the outside to be parallel to your reamed hole.
              #287838
              HOWARDT
                @howardt
                At 6x diameter the hole too deep to drill accurately. As Spurry says mount on a mandrel and re-finish the od. I also wonder why the hole needs to be reamed all the way through. If the hole is for a holding spindle, fit the spindle and mount the assembly in a chuck to bore the die bore.
                #287851
                Chris Gunn
                  @chrisgunn36534
                  It seems like you started off with a fairly small drill which would be very prone to wander over 3" the next drills would just follow the first. you might have got a better result drilling with the 31/64" drill only. For best results drill 15/32", bore out to 31/64" or .490" also not easy over 3", then ream.
                  Chris Gunn
                  #287864
                  John Haine
                    @johnhaine32865
                    I use the biggest drill I can to start a long hole specifically so that it is as rigid as possible to minimise the chance of wander. I have a number of "pilot point" drills that have are rather like 2-flute slot drills at the end except for a short split-point bit of reduced diameter to start the drill off in the right plave. They need no more than a minimum centre drill to start and drill very fast and true. So for a 1/2" hole I'd start with an 11mm drill so I only had 1.7mm for the second drill to remove.
                    Given that the 1/2" is presumably for the guide rod that the holder will slide on, you could bore it out to say 13mm and get a piece of 13mm silver steel which I think is a standard size, rather than use 1/2". Boring will endure that the hole is concentric to tha lathe axis.
                    #287865
                    Peter Simpson 1
                      @petersimpson1
                      Spurry The majority of the 3 inches were located within the chuck. As I started off with 3/16" pilot drill this where to problem started. As for reaming the total hole. It seemed easier and more accurate than using a smallish boring bar. Next time I will start off with a near full size drill.
                      #287878
                      julian atkins
                        @julianatkins58923
                        Well, I can drill a 21 thou drill to 7/16th depth in the lathe which is 20 times drill diameter to depth with it being perfectly accurate and true…
                        Something is wrong with Peter's set up. I dont know what it is.
                        My homemade tailstock dieholders have a 5/8" register for 2MT.
                        Cheers,
                        Julian
                        #287891
                        Bob Stevenson
                          @bobstevenson13909
                          Indian made 'budget' 4 jaw by any chance?…..checked the jaws for parallel internal surfaces?
                          #287893
                          thaiguzzi
                            @thaiguzzi
                            Should have been bored clean, hence concentric with OD, prior to reaming, or finish bored.
                            #287903
                              Trying to drill, starting with a flimsy, flexible, drill is flawed. One must start with a rigid cutter such as a lathe centre drill. Further, the tail stock will never be perfectly centred vertically and horizontally (even if well within the machine specs). Starting the hole from an off-centre point will invariably cause some misalighnment of the hole. It may well be straight, but not necessarily parallel over the distance the OP expecting.
                              One of the reasons why model engineers bore cylinders. One of those very good reasons is to achieve parallelism.
                              Another ploy by those same people is to straighten pilot holes by drilling with a stiff/rigid end mill and not a twist drill (which will tend to follow the pilot hole).
                              'Nuff said?
                              #287904
                              Jon Gibbs
                                @jongibbs59756
                                +1 for Chris Gunn's comments.
                                Your smaller pilot drills, even though started with a centre drill (a spotting drill is better), will wander unless they are sharp, you clear the flutes often and don't use too much pressure.
                                Jon
                                #287941
                                John P
                                  @johnp77052
                                  To be able to drill straight and true through shafts this useful publication
                                  from Camden books is worth looking at. "Making rifle barrels",it is about
                                  drilling long straight holes ,some of it is about using gun drilling which would
                                  probably be beyond the capability of most model engineers workshops but
                                  there are sections giving advice on conventional drilling which result in
                                  drilling straight holes.
                                  I have used these methods for some of the examples shown here in the second photo.
                                  The shaft seen here in the lathe is 8 5/8 inches long and drilled through
                                  at 14 mm (.551 in) .Using 2 extended drills a smaller diameter pilot drill
                                  has a bored hole formed to be a close fit at least 5x drill diameter and the hole
                                  drilled at least another 8 to 10 x drill diameter ,the 14 mm drill size is also
                                  bored a close fit and drilled to open the hole leaving at least 5 x depth
                                  of the smaller diameter so the hole depth can be advanced.By changing drills
                                  the hole is drilled right through.As can be seen in the photo a good supply of
                                  neat cutting oil helps by cooling and lubricating and washing the drill and hole
                                  of all swarf ,the drills should be withdrawn often to to clear the swarf and avoid
                                  crowding the flutes.Two similar shafts were made one came out on centre the
                                  other disappointingly was .002 inch off centre but probably within the accuracy
                                  of the 3 jaw chuck. At full depth the hole is only 16 x the drill diameter.Using the
                                  hole as the reference the shafts were re-centred and the finished from there.
                                  The third photo shows one of 3 internal grinding spindles at 6 5/8 inches long
                                  and drilled through at 7.3mm dia ,the hole depth is 22 x diameter .As can be seen
                                  the shaft is held in the 4 jaw and supported by the fixed steady using a similar
                                  sequence as previously the holes were drilled ,one as before was on true centre
                                  the other .002 inch off ,the photo shows the last part of the sequence the shafts
                                  having been referenced from the hole re-centred and rough turned to true up
                                  to turn the 1 morse taper in the nose as in the photo .
                                  The drills are sharpened as 4 facet drills ensuring the cutting edges are the same
                                  each side.
                                  The moral of the tale is if you start off with true hole the drill will most likely
                                  follow it through.
                                  #287956
                                    SOP is to drill the hole well undersize to quickly remove metal in a rough manner. Then bore the hole to slightly undersize to ensure the hole is parallel and concentric. Then finish to size with a reamer. For a 1/2" hole, drilling to 7/16 or 15/32" then boring to 5 to 10 thou undersize should work OK.
                                    If you don't bore the hole, the reamer will follow the wobbly drilled hole, as you have found out.
                                    #287969
                                    Spurry
                                      @spurry
                                      Posted by Hopper on 09/03/2017 12:32:45:
                                      What sort of boring tool would you be using for this type of procedure?
                                      #287976
                                        Posted by Spurry on 09/03/2017 15:09:48:
                                        For a hole less than 1/2" I use a tool like aD-bit ground from HSS
                                        For 1/2" and above I just use one of several small standard boring bars.
                                        #287994
                                        Enough!
                                          @enough
                                          Posted by not done it yet on 09/03/2017 08:09:06:
                                          …Further, the tail stock will never be perfectly centred vertically and horizontally (even if well within the machine specs).
                                          … and yet, said tailstock will form the reference axis for the tool when its finished and being used to cut threads.
                                          I have serious doubts about the emphasis in this thread on perfection of the hole size/straightness for something as prosaic as a die-holder. For everyday threading, a tiny amount of wobble isn't going to be noticeable (look at the average tap wrench). If significant accuracy of a thread is required on occasion, then cut it.
                                          #287995
                                          Spurry
                                            @spurry
                                            Posted by Neil Wyatt on 09/03/2017 15:37:08:
                                            Thanks Neil.
                                            Peteenlightened
                                            #288039
                                              +1 on this, but I grind the tool something like a D bit but for a 1/2" hole I would probbly use a piece of 3/8" or maybe 5/16" round HSS. It is then held so the shank is at an angle of say 5 or 10 degrees from parallel with the lathe main axis. Thus it is cutting as a boring tool on the front lefthand corner (as viewed from the tailstock) rather than drilling as a D bit.
                                              Probably with a 1/2" hole almost 3" deep there will be a bit of chattering going on. Just take light cuts at teh finish, running the tool through job at the same setting several times until no more cutting is taking place. The reamer will take care of any chatter marks. All that matters at the boring stage is that the hole is basically concentric and straight; surface finish not important.
                                              #288046
                                              bricky
                                                @bricky
                                                I have had to drill a 1/2' hole 21/2" and was told by an old timer to drill just undersize for 1" and then use a D bit, having got this length parallel use the undersize drill again and follow with the D bit, the first 1" of parallel hole will guide the D bit to complete the job.This worked well.
                                                Frank
                                                #288084
                                                Peter Simpson 1
                                                  @petersimpson1
                                                  Went back into the workshop yesterday and started again. Faced both ends of the bar to finished length 2 !/2 "
                                                  Set the bar stock up in the 4 jaw chuck centre drilled and then drilled into the bar stock with an 11mm drill to a depth of 1 1/4 " reversed the stock on the chuck and did the same thing. Finished to 1/2 all the way through with a boring bar. Now spot on. Seem to be cheating doing it that way but it worked.
                                                  #288092
                                                  Tony Pratt 1
                                                    @tonypratt1
                                                    Posted by Peter Simpson 1 on 10/03/2017 11:11:58:
                                                    Cheating, how so?
                                                    Tony
                                                    #288101
                                                    Chris Gunn
                                                      @chrisgunn36534
                                                      Peter, glad you got it done, but not cheating at all, just following the advice of many who advised boring the hole prior to reaming.
                                                      Chris Gunn
