Posted by john dakin on 14/01/2017 20:17:17:
…..I'm trying to make an indexing plate that is 160mm in diameter and I need to put 360 1mm holes on the first outer index, is there some sort of formula to work out if they will all fit without the holes overlapping and breaking in to each other
Yes, but there's not enough information to be able to use it. One needs to know the diameter on which the holes are placed, not the outside diameter of the plate.
In practical terms no the holes won't break into each other, but the gap between them won't be large ~0.4mm.
