I cut a lot of small pieces of thin wood (square dowel etc) to the same lengths.
Its a bit tedious marking each to length putting it in a vice, sawing to the pencil mark, sanding the excess etc.
I picture a tool that i can set to a length (like a vernier caliper) drop a piece of wood in, tighten and cut off the excess sticking out, against a hard edge with a razor saw, then repeat.
Does such a thing exist or is there a relatively easy solution to put together for someone with only hobby level tools?
I can see how i would make a gig for one specific length that i could put in a vice, but while I might want several matching pieces, the length would change job to job, and that sounds like making as much work as it solves.
