The world of model and hobby engineering
Forums
Help
Register
Log in
Home › Forums › Beginners questions › Milling depth of cut
Is there a good rule on the max depth of cut that can be used for slot milling?
Is that the same for end milling?
Is 1/3 of the cutter diameter correct?
Typically 1/2 x diameter for slot drills 1/4 D for end mills but a lot depends on the rigidity of your mill. For light hobby mills perhaps half that.
Russell.
Depending on material and set-up I start at cutter diameter as max depth of cut for a slot using a 2 flute cutter.
Emgee
And what is the reason for this limitation is it the strength of the cutter or the removal of swarf?
If it is swarf can you cut through a material to a greater depth than you can cut a slot in it?
Started by: Duff Machinist in: General Questions
Duff Machinist
Started by: Vic in: Workshop Tools and Tooling
vic newey
Started by: Geoff Dunsby in: General Questions
southernchap
Started by: Andrew Tinsley in: General Questions
duncan webster 1
Started by: Macolm in: Workshop Tools and Tooling
Started by: JasonB in: The Tea Room
mgnbuk
Started by: Clive Farrar in: General Questions
Macolm
Started by: heavydamper64 in: Traction engines
Chris Gunn
Started by: IanT in: Workshop Tools and Tooling
noel shelley
Started by: JA in: The Tea Room
JA
Started by: Paul Mills 4 in: Model Engineer.
Started by: michael howarth 1 in: General Questions
Dell
Started by: carlw in: Clocks and Scientific Instruments
Started by: Ian Kitson in: Hints And Tips for model engineers
Started by: blowlamp in: CAD – Technical drawing & design
Russell Eberhardt
Started by: Ron Colvin in: CAD – Technical drawing & design
blowlamp
Started by: Geoff Byman in: Manual machine tools
Started by: John MC in: CAD – Technical drawing & design
Started by: Peter Hoerlein in: Work In Progress and completed items
Peter Hoerlein
Started by: Machine-DRO in: Website Announcements
Started by: Phil Whitley in: The Tea Room
Phil Whitley
Started by: Michael Gilligan in: Manual machine tools
old mart
Started by: Dalboy in: Materials
Pete
Andy Stopford
