Press fit bush
Press fit bush
Home Forums Beginners questions Press fit bush
  • #255687
    Daniel
      @daniel
      Hello All,
      I need to make a bronze bush to fit into a cast iron tractor clutch pedal.
      The clevis pin hole is well oval.
      I have plunge milled the pedal out to 14mm and the clevis pin is 10mm.
      With a 2mm wall on a bronze bush having an interference fit (pressed),
      into cast iron, what outside diameter would be recommended for the bush?
      I imagine a slight tad over 14, but how much would this slight tad be ?
      Exactly ?
      Thanks in advance for any help
      #8288
      Daniel
        @daniel
        #255689
          Posted by Daniel on 13/09/2016 18:05:36:
          With a 2mm wall on a bronze bush …
          Exactly ?
          I flatly refuse to discuss exact tads with a man who works in whole millimetres devil
          … But you may find this useful:
          http://www.tribology-abc.com/calculators/e3_8.htm
          Edited By Michael Gilligan on 13/09/2016 18:27:38
          #255690
          Martin Connelly
            @martinconnelly55370
            Loctite it to avoid tensile forces in the cast iron.
            Martin
            #255692
              I would also check your hole as plunge milling may be spot on but more likely a tad under or a tad over 14mm.
              For a practical idea I have just mic'd a sintered bronze bush and it is 0.003" oversize on 3/4" nominal size, not tapered. So thats a a tad over 0.075mm for the press if but if the iron is a bit thin you may want to try 0.04-0.05mm over bore dia
              #255694
                If feasible, ream the bush after fitting, if the fit is critical, (which I guess it isn't).
                #255702
                speelwerk
                  @speelwerk
                  I support Martin, a 2 mm wall in cast iron will fracture without warning. Niko.
                  #255704
                    We don't know how thick the iron pedal is.
                    The hole in the pedal is now 14mm, the pin it pivots on is 10mm which gives the BUSh a 2mm wall thickness
                    #255718
                    HOWARDT
                      @howardt
                      Have a look at Oilite, Manganese Bronze. Although these are not re-machined after fitting, they achieve the correct bore after being press fitted into the correct hole.
                      #255723
                      Daniel
                        @daniel
                        Posted by Michael Gilligan on 13/09/2016 18:23:53:
                        Thank you for the link. That is a cool calculator.
                        The complete absence of any decimal points, let alone anything after them, was an effort to maintain the agricultural spirit of the adventure. However, even as I pressed the "create thread" button, I saw that this was doomed. At some point I would need to resort to something a bit smaller. It's a pity that the DRO doesn't do Tads, really. dont know
                        #255780
                        Daniel
                          @daniel
                          Thank's everyone for the replies. Last night's forum time was cut short by a storm and power failure.
                          Martin – I had temporarily forgotten about Loctite; that is most likely the way to go.
                          Neil – I will ream the bush after fitting. Critical it isn't, by any stretch of the imagination, but seems good form.
                          Jason – The pedal is about 15mm thick. My tape measure is not equiped with smaller increments.
                          And, of course, for the loctite solution, the finished article only needs to be a Tad, or two, under 14mm.
                          No unnecessary stresses, etc, either on me, or the pedal, and not a decimal point in sight. laugh
                          #255790
                          JohnF
                            @johnf59703
                            Daniel, if it's the clutch foot pedal I doubt it is cast iron, more likely a steel forging. What tractor is it ?
                            Edited By JohnF on 14/09/2016 08:31:12
                            #255795
                              PostScript: … For the benefit of those who may not be familiar with the term:
                              A 'tad' [or more properly, T.A.D] is a Tiny Atypical Dimension
                              Example: On a drawing generally dimensioned in inches; one micron would be a 'tad'
                              or, when referencing whole millimetres; tenths of a thou would be 'tads'
                              angel MichaelG.
                              #255798
                              MW
                                @mw27036
                                Posted by JohnF on 14/09/2016 08:30:41:
                                You're probably right, i can't imagine that being a casting either.
                                Michael W
                                #255803
                                  Posted by Michael Gilligan on 14/09/2016 08:59:44:
                                  angel MichaelG.
                                  [ BLUFF ]
                                  #255806
                                  Chris Evans 6
                                    @chrisevans6
                                    From a practical point of view it would not matter if the bush was loose on the peddle hole by a couple of thou. It will not wear the peddle out in your lifetime and will be retained by the peddle fixing.
                                    #255822
                                      angel MichaelG.
                                      [ BLUFF ]
                                      #255839
                                      Daniel
                                        @daniel
                                        Micheal – That saved me the trouble of some research. I was convinced that a Tad was a more or less precise measurement. It's true that whole millimetres can be a bit (tad), cumbersome.
                                        I've sometimes been known to use "half a Tad", but that is only on extremely precise work., and somewhat rare.
                                        The (non) deliberate mitsake of referring to the clutch pedal as cast iron is just that; a mistake.
                                        As pointed out, it is most likely a steel forging or similar.
                                        The tractor is a Someca 40 & French.
                                        Chris – quite agree with you, that the bush could even float. I just wanted to do a reasonable job for the simple pleasure of doing so; as with most of what we get up to. Avoiding any unnecessary accuracy, of course. smile p
                                        #255841
                                        Daniel
                                          @daniel
                                          Sorry – can I change the thread title now ?
                                          I'm thinking "Loosely Fitting Bush", may be more appropriate.
                                          #255859
                                          duncan webster 1
                                            @duncanwebster1
                                            Exactly ?
                                            For the diehard Imperial brigade I'm considering making a Micrometer which reads in 1/1024" increments. That's 2 to the power 10, and is a logical extension of 1/8", 1/16" etc. Any takers?
                                            #255863
                                              Posted by duncan webster on 14/09/2016 15:43:35:
                                              Works even better if we redefine the inch to be 25.6mm as well.
                                                Posted by SillyOldDuffer on 14/09/2016 15:59:23:
                                                Couldn't agree more, Dave yes
                                                deja vu **LINK**
                                                http://www.model-engineer.co.uk/forums/postings.asp?th=94488
                                                  Posted by Michael Gilligan on 14/09/2016 18:55:20:
                                                  deja vu **LINK**
                                                  Well I never! One day if I keep trying I might have an original idea. I'm leaving it a bit late though.
                                                  Cheers,
