grinding a masonry drill for steel
Home Forums Beginners questions grinding a masonry drill for steel
  • This topic has 14 replies, 13 voices, and was last updated 3 June 2015 at 09:58 by John Stevenson 1.
  • #7650
    nigel jones 5
      @nigeljones5
      #192154
      nigel jones 5
        @nigeljones5
        what are they made from (main drill body) and can they be ground for steel?
        #192166
          Posted by fizzy on 02/06/2015 21:02:00:
          what are they made from (main drill body) ? … Non-descript steel [approximating Cheese]
          can they be ground for steel? … Geometry, Yes … Durable edge, No
          #192169
          Ady1
            @ady1
            I've ground the carbide tip for doing stainless steel.
            The main body appeared to be ordinary steel on my cheapo masonry drills
            Drilled it using the backgear, less heat
            #192170
            John Haine
              @johnhaine32865
              The tip is tungsten carbide and can be ground to a sort of point for steel I understand. I think some sort of 4 facet grind would work. I can't remember where I saw this but could be useful if you have something too hard for a normal drill.
              #192172
                (main drill body)
                #192174
                David Colwill
                  @davidcolwill19261
                  The body of the drill varies according to quality, the better ones are made from a tough steel and the cheap ones from cream cheese. I have used this dodge on more than one occasion, usually involving a steel of unknown origin that has work hardened to the point that HSS won't touch it. I can sharpen drills by hand ( after a fashion ) and the technique I use for sharpening is to present the masonry drill in exactly the same way I would with an ordinary drill. I should point out that I have only used these drills for opening out holes already drilled. Also the carbide tips are very small and prone to breaking. I only really use this as a last resort.
                  Regards.
                  David.
                  #192175
                  Capstan Speaking
                    @capstanspeaking95294
                    Definitely do-able if you can't buy a proper t.c. drill.
                    Grind the negative rake off the end. Even then the "top rake" is an unhelpful 90 degrees.
                    The tip is soft-soldered in so the slightest heat and it's gone.
                    #192179
                    Bob Brown 1
                      @bobbrown1
                      You can buy masonry bit that have a ground edge to drill a variety of materials including steel see **LINK**
                      To quote "High performance bits with multiple diamond-ground carbide tips.
                      Suitable for masonry, wood, aluminium, structural steel, plastic, concrete B35 and multi-layer materials such as tile on concrete."
                      I've used them to drill though aluminium then into brick also wood into brick/concrete block.
                      Bob
                      Edited By Bob Brown 1 on 02/06/2015 22:29:37
                      #192180
                      Vic
                        @vic
                        If you need to open up a hole in tough material you can use a Glass drill as it is, the leaf shape works quite well.
                        #192199
                          Couple of pics of some commercial TCT twistdrills I have to give you an idea of how to grind, tips are brazed like most masonary drills so will stay put. Looks to hace a 4 facet type grind with a very shallow angle to the first edge .
                          Edited By JasonB on 03/06/2015 10:05:46
                          #192201
                          Gordon W
                            @gordonw
                            Masonry drill quality is very variable, all the decent ones I have the tips are brazed on. Sharpening is quite easy, just a sort of 4 facet spade drill. Cheap diamond disc in angle grinder is the easiest and cheapest way, touch up on green grit wheel. I've done this mostly when drilling in multi-media jobs.
                            #192205
                            Jon Gibbs
                              @jongibbs59756
                              I've had some success with spear point tile drills if this helps.
                              The other option is to try something like the Bosch Multi-construction drill bits but these aren't as sharp from my experience.
                              In both cases high drilling pressures are needed.
                              Jon
                              #192207
                              Danny M2Z
                                @dannym2z
                                Posted by JasonB on 03/06/2015 08:48:19:
                                Couple of pics of some TCT twistdrills I have to give you an idea of how to grind, tips are brazed like most masonary drills so will stay put.
                                Nice photo's Jason, I had always wondered if it was worth attacking my brazed tip masonry drill bits with a suitable grinding wheel. Unlike another thread the grinding wheel striations are a part of being a practical bloke. I bet the hole won't mind
                                * Danny M *
                                #192210
                                John Stevenson 1
                                  @johnstevenson1
                                  Posted by Danny M2Z on 03/06/2015 09:42:04:
                                  * Danny M *
                                  LOL wink
                                  Ground quite a few up to get John out of trouble.
                                  Diamond wheel and grind 4 facet, they work fine but don't expect H7 tolerance.
                                  Try to use a decent drill, anything that has a chrome shank is suspect.
