Help needed with Spark Erosion
Home Forums Beginners questions Help needed with Spark Erosion
  • #7375
    Raymond Hodges
      @raymondhodges20973
      #170096
      Raymond Hodges
        @raymondhodges20973
        Hello fellow members
        In the web site called MikesWorkshop he describes the making of a very basic Spark Erosion Apparatus.
        In the circuit diagram is a 470uF capacitor could someone tell me what voltage rating would be apropriate for this capacitor, the DC voltage used in this circuit is 21v.
        The capacitor is conected between the anode and base.
        I havn't much idea of electronics exept i am able to read a circuit diagram.
        Thank you
        Ray
        Edited By Raymond Hodges on 19/11/2014 20:33:20
        #170097
        AndyP
          @andyp13730
          I have built and used a simple spark eroder and although it is not the same the capacitors in mine that perform the same function are 2 off 150uF 220v electrolytics wired in parallel. Mine works best at around 36v but it is fed by a variac so that is a little vague.
          Andy
          #170102
          Raymond Hodges
            @raymondhodges20973
            Hello Andy
            Thank you I'l keep that in mind.
            Oh i forgot to mention, do i need to take any precautions against Radio and TV interference.
            Ray
            #170104
            Michael Cox 1
              @michaelcox1
              Hi Ray,
              I used 50V capacitors when I built the spark eroder. These have given no problems.
              I hope this helps.
              Mike (of mikesworkshop.weebly.com)
              #170105
              AndyP
                @andyp13730
                I don't know about interference, it doesn't wreck the radio in the workshop unlike the 3d printer and the family haven't complained so maybe not.
                Andy
                #170129
                Raymond Hodges
                  @raymondhodges20973
                  Thanks Andy and Mike i now know what to do
                  Btw Mike your web site is very informative along with the Gadget Builder web site i am getting exelent ideas for my little workshop.
                  Again thank you both
                  Ray
                  #170137
                  Michael Cox 1
                    @michaelcox1
                    Hi Ray,
                    Thanks for the kind words about the website.
                    #170140
                    Ian S C
                      @iansc
                      Ray, any thing from around 50V and up, usually depends on what you can find. If a component is specified, and you can't get that spec, go up, same with resistors, might be 1/2 Watt on diagram, but it doesn't matter if you use 5 Watts, but it could if you used 1/4 Watt.
                      You can see I'm a junk box electronics dabbler.
                      Ian S C
                      #170180
                      Bodgit Fixit and Run
                        @bodgitfixitandrun
                        just visited the website. There's an interesting usb shadowgraph / microscope on there. I quite fancy making that along with the spark eroder. I worked for several years as a chemical machinist. and whilst this isn't the same it will help with some interesting jobs like removing broken taps and drill etc. I can also see a use for getting broken bleed nipples out of brake callipers.
                        #170211
                        Raymond Hodges
                          @raymondhodges20973
                          well Bodgit thats just why i aim to build one, i broke a 2mm tap,tried Alum and Citric acid had no luck so decided this was the solution.
                          I asume you are refering to Mikes web site for the shadowgraph / microscope.
                          Ray
                          #170246
                          Ian S C
                            @iansc
                            Ray, did you try warming the Alum solution, and try to poke a thin bit of wire down the side of the tap to get the air out.
                            Ian S C
                            #170274
                              @bodgitfixitandrun
                              Hi Ray
                              Yes I am referring to Mikes website. There's some really useful stuff there. Let us know how you get on.
                              #170292
                              Raymond Hodges
                                @raymondhodges20973
                                Yes Ian and blew the hole through every day for a week.
                                The joke is i broke the tap removing it from the hole the thread was done.
                                The citric acid is working better but for the future i will make a simple spark eroder, 2mm an hour is better than a week or more waiting for a chemical to work.
                                Mikes website and gadgetmaker's website are great for mod's information.
                                Thanks everyone for your help
                                Ray
                                #170508
                                Raymond Hodges
                                  @raymondhodges20973
                                  One last question on Mike,
                                  does it matter if i use electrolitic condensers.
                                  Ray
                                  #170510
                                  Ian S C
                                    @iansc
                                    Ray, at that capacity, electrolitics are what you get, stick to the circuit diagram.
                                    Ian S C
                                    #170528
                                    Michael Cox 1
                                      @michaelcox1
                                      Hi Ray,
                                      As Ian says for that capacitance you are only likely to get electrolyics. The only thing to be aware of is that electrolytic capacitors are polarised with a '+' and a '- ' terminal/wire. It is important that they are connected in the circuit correctly or they will last only a few minutes and probably end their life with a bit of a bang and a lot of mess spattered over the circuit board.
                                      #170529
                                      Raymond Hodges
                                        @raymondhodges20973
                                        Thank you Ian
                                        Thank you Mike
                                        I'l take care not to prove the big bank theory wink
                                        Ray
                                        #170555
                                          You can get 470uF tantalum bead capacitors. I wouldn't recommend them for this application, though one forum member may have a few he would like to quietly pass on…
                                          Ian S C
                                            @iansc
                                            I don't know it Tantalium caps have a high enough voltage rating.
                                            Somewhere in my supply department I have some 400uf 300V Non polarised capacitors, I think they polarise them selves once they are installed, I'v never used them.
                                            Ian S C
                                            #170673
                                            mark costello 1
                                              @markcostello1
                                              Have You tried turning the tap with a pair of small wires, not stated anywhere in a previous message? May not be all that tight.
                                              #170953
                                              Raymond Hodges
                                                @raymondhodges20973
                                                Two needles and a pair of pliers was my first try but the tap was too tight.
                                                Next i tried alum for a few days nothing happend, then 25% citic acid this eventualy worked and after a week the taped hole was free.
                                                Now i am in the process of building a simple spark eroder as decribed by Mike Cox in his web site.
                                                The acid is ok for non ferous parts but not for steel, hence the very simple EDM.
                                                Thank you all for your advice.
                                                Ray
