Expanding mandrels
Expanding mandrels
Home Forums Beginners questions Expanding mandrels
  • #5859
    Peter Wood 5
      @peterwood5
      How do I make them?
      #81937
      Peter Wood 5
        @peterwood5
        My latest stationary engine project by Anthony Mount needs a couple of parts to be mounted and turned on expanding mandrels of 8 and 11mm od.
        I cannot justify purchasing commercial items but I believe they are quite easy to make.
        However the only info I can find is on American forums and refers to the use of ‘pipe plugs’, whatever they are.
        Can anyone give me a pointer to how to make them pls.
        Peter
        #81938
        Michael Cox 1
          @michaelcox1
          Sparey in his book “The Amateurs Lathe” suggests a very simple form of expanding mandrel. Take a piece of bar and turn it down to the correct diameter. Now drill and tap the end using a taper tap. Slit the end of the bar into four quadrants using a hacksaw. If the part is pushed on the end and a screw is tightened on the hole then the mandrel expands when the tip of the screw reaches the taper section of thread. I have used this method works many times and it works very well.
          If concentricity is very important then all the operations to prepare the mandrel can be performed on the lathe without romoving it from the chuck. Slitting the mandrel is the most difficult part but it is possible.
          #81939
            Ramon may well be along later but have a look at this recent post of his detailing simple expanding mandrels. By slitting then doing teh final machining you keep things concentric
            Another method is to turn a bar end to a good fit in the hole and then put a slight taper onto teh chuck end, only needs about 1deg you can then just push the part onto the taper.
            J
            #81945
            Ramon Wilson
              @ramonwilson3
              Hi Peter,
              Jason points out a good
              alternative and it is one I frequently use but the fit has to be just
              right and the materials compatible if picking up is to be avoided.
              Personally
              I much prefer the expanding type which are so easilly made and work so
              efficiently -there is not the worry of similar metals picking up either
              Here are a few pics from the Racer build which though seen before by most may help you and someone else too at this point in time
              Most of mine are made from steel but that is not
              critical. They are all expanded by a normal cap head screw that has had
              the head turned a 60degree taper to match a centre drill Rough the
              mandrel to with .5mm and drill and tap and centre deeply. using a
              parting tool relieve a portion at the front of the mandrel.
              Remove from the chuck and make two or more cuts with a hacksaw down into the main part. Deburr then return to the lathe
              and screw the caphead in until it just nips then turn the od to a
              finished size to suit your bore. I’m sure you will find it quite
              surprising just how little torque you require on the screw to hold the part firmly for turning.
              These are great little aids, very quick and easy to make and work extremely well.
              Hope this helps
              Regards – Ramon
              #81958
              David Colwill
                @davidcolwill19261
                That’s a neat trick, will have to remember that. Thanks
                #81961
                Peter Wood 5
                  @peterwood5
                  Jason, Ramon
                  Following Jason’s posting I popped into the workshop and knocked up an 8mm mandrel in about 10minutes using the tapered socket head screw method.
                  I then used it to hold the pair of cranks on which I had to turn a small boss. Worked like a dream.!!
                  I was surprised how little tightening the screw needed before it had a very firm grip.
                  Since then I have read Ramon’s posting and will refine the construction of future mandrels with the deep centre drilled end and the relief in the middle.
                  I now have the confidence to move onto the larger item.
                  Thank you both very much.
                  Peter
                  #81988
                  Sub Mandrel
                    @submandrel
                    I turned the flanges on my loco wheels today. I normally use the taper tap method, but I wanted 100% accuracy, so I took a length of 1 1/4″ bar (only because it had a 1/2″ mandrel at the other end) and turned a parallel stub a close fit for the reamed wheels (3/8″) but slightly short. Drilled and tapped M6 and used a thick brass washer to hold the wheels in place for turning them.I didn’t have any slippage – the wheels are 2 1/4″ diameter.
