Myford Question
Myford Question
Home Forums Model Engineer & Workshop Myford Question
  • #38590
    Chuck Taper
      @chucktaper
      #513110
      Chuck Taper
        @chucktaper
        Theoretically (?) would a Super7 headstock & spindle fit on an ML7 base. If so what issues, if any, are likely.
        Regards.
        FC
        #513126
        peak4
          @peak4
          I don't have personal experience, but having checked a pdf of both manuals for ML7 & S7, they both show the same part number for the bed. A8724/1 for the short bed.
          Bill
          #513138
          Mike Henderson 1
            @mikehenderson1
            It all depends on the ML7!!
            The late ML7R is really a lite model super 7 and uses the same bed. The early ML7 that predated the first Super7 and stayed in production alongside was a very different beast and did not share the bed casting.
            Whether the Super7 headstock could be physically fitted I don't know but wouldn't expect so. That said, the gap between the shears must be the same since both lathes use the same fixed steady. Can anyone do some measuring?
            #513158
            Keith Anderson 1
              @keithanderson1
              You probably can
              The later long bed ML7 has a super7 bed, saddle, block gin stripped cross and 360 degree top slides, with an ML7 headstock.
              I don't know about which tailstock was used, it was missing from the one that I got.
              #513159
              Keith Anderson 1
                @keithanderson1
                Gib strip
                #513160
                peak4
                  @peak4
                  Posted by Mike Henderson 1 on 12/12/2020 17:26:47:
                  The parts list where I checked the numbers for the ML7 was dated 1997, but was certainly for a pre-ML7R, with the more upright headstock arrangement
                  According to the ML7 build spreadsheet I have, the bed casting changed in 1973, but it doesn't explain the modification.
                  KSL 110296 C 1973 LONG BED CASTING CHANGED
                  K 110296 C 1973 STANDARD BED CASTING CHANGED
                  K 111727 1973 APRIL 3/4 " LEADSCREW & REDESIGNED BED
                  Bill
