DRO installation – a salutary lesson
Home Forums Model Engineer & Workshop DRO installation – a salutary lesson
  • #488198
    Bob Wild
      @bobwild67557
      I bought a Digital Readout kit from a reputable seller to install on my new milling machine. The y-axis assembly went on fine, but I had a terrible time getting a stable reading from the x-axis one. The reading fluctuated wildly even when the bed was stationary. At first I thought it was due to some sort of misalignment and spent ages tweeking and adjusting the mountings but to no avail. Then I got to wondering about the way the measuring head was screwed down. For the most rigid method I changed the screws which were supplied and used my own countersunk screws. I had already made sure that they did not foul the sliding scale, but I discovered that if I released them by a couple of threads the problem went away. So the solution was to shorten them by two mm, and bingo everything was hunky dory.
      I’m not an electronics expert, but I’m most intrigued to know the technology and how a piece of steel in close proximity could cause such interference? Any reply from a knowledgeable guy would be most appreciated.
      Bob
      #38575
      Bob Wild
        @bobwild67557
        #488216
        Chris Evans 6
          @chrisevans6
          Could it be that the screws used transmitted an electronic circuit or magnetic field ? I await the experts opinions as this has intrigued me.
          #488227
          Stuart Bridger
            @stuartbridger82290
            There have been other posts on this subject recently that have highlighted potential earthing issues with the machines, that has resulted in earthing currents flowing through the DRO cables. This is a potential safety issue that needs to be addressed ASAP.
            1) Check all exposed metalwork on the mill has continuity to mains earth. I would disconnect the DRO scales from the console for the duration of the test ready to eliminate this path
            2) Your DRO console should have an earthing point, make sure that that this is connected to the mill metalwork at one point.
            #488236
            mgnbuk
              @mgnbuk
              Magnetic or optical scales ?
              At a guess, magnetic.
              Nigel B.
              #488243
              Bryan Cedar 1
                @bryancedar1
                I wonder if the screws were distorting the internals in any way and causing a bad connection on the electronics?
                #488246
                Dave Halford
                  @davehalford22513
                  Bob most scales have to be installed to a tolerance that is sometimes quite a narrow window.
                  Your mystery scales might be just on the border line or there's a dry joint or dicky cable. if the metal was important they would have supplied ally or brass screws.
                  #488247
                  Ian P
                    @ianp
                    Posted by Bryan Cedar 1 on 30/07/2020 10:36:38:
                    I think this is the most likely reason too.
                    From the OP's original information it is nigh on impossible to give a meaningful answer, all we know is one axis worked and one didn't, but we have no idea of what type of DRO this is and even less idea of the actual mounting details. The fact that loosening the fixings changed the behaviour is a clear indication (to me) that something was being distorted even if the ends of the screws were not fouling on anything.
                    Although the DRO is now working, if it were mine I would want to know the actual cause of the problem.
                    Ian P
                    #488250
                    Dave Halford
                      @davehalford22513
                      Posted by Ian P on 30/07/2020 11:17:36:
                      Ian P
                      He said that he shortened the fixings by 2mm and it's all OK. Surely we can assume that they still aren't still flapping about 2 threads loose.
                      #488262
                      Ian P
                        @ianp
                        Dave, but is was the 'loosening' that cleared the fault and we have no idea what the term meant. 'If' the loosening was just a quarter turn the its unlikely that is was the protruding threads making contact with anything.
                        Ian P
                        #488272
                        Dave Halford
                          @davehalford22513
                          Posted by Ian P on 30/07/2020 13:07:36:
                          Ian P
                          A couple of threads was mentioned in the OP Ian, which to me meant the read head would wobble if left like it.
                          #488292
                          John Haine
                            @johnhaine32865
                            FWIW I fitted an M-DRO kit of mag scales, and I did have one problem that wasn't mentioned in the instructions.
                            I mounted the sensors on the small ali blocks provided and found that the strain relief where the cable entered the sensor body was slightly larger than the body itself, so that if you tried to tighten the screws the connection would be put under strain. To obviate this I put a washer or two between the sensor and the mount for packing, to allow the bolts to be fully tightened without straining the connection. The installation mainly went swimmingly, I had no problems and it performs very well. The third place of decimals on the display is rock solid to 5 microns (the resolution), it only changes slightly, sometimes, when you tighten the slide lock.
                            #488312
                            Richard –
                              @richard-3
                              I bought a M250 with a industry quality DRO fitted when new (optical). Had a readout problem after fitting a VFD, this that was completely cured by earthing the readout.
                              Richard
                              #488385
                              Bob Wild
                                @bobwild67557
                                Thanks for all your replies, although no-one has explained how these things actually work.
                                #Ian P – not sure if I was allowed to mention brands, but what the heck – it was bought from Arceurotrade. There is no info on their website as to the type.. The part no is 100-061-00500.
                                #Stuart Bridger – there is no facility to earth the unit. In fact the display unit is supplied with a plastic mounting plate with keyhole slots to slide it in. It is battery operated, so I'm not sure whether an earth is necessary.
                                #mgnbuk – Looking inside I cant see any light ?!? so I suspect it is magnetic
                                #Bryan Ceder – I could see the screws when the scale bar is removed and it did not touch or distort anything.
                                #Dave Halford – absolutely correct. I tightened the screws after I shortened them.
                                I could vent my spleen about the fact that the documentation provided only described how to use the thing and not how install it. Although it was titled "Digital Scale with Steel Deam Instruction". Your guess is as good as mine as to what that means. Not to mention the four other spelling mistakes. I would have thought any self respecting supplier would proof read with due diligence anything coming from abroad where English is not the native tongue. But that is a digression.
                                Bob
                                PS New restrictions tonight in Kirklees means I shall have more time for the man cave.
                                #488396
                                John Haine
                                  @johnhaine32865
                                  Capacitive
                                  #488434
                                  mgnbuk
                                    @mgnbuk
                                    You are affected by the antics of the residents of Ravensthorpe & Dewsbury as well then Bob. No wonder there are calls from Huddersfield residents that those areas are are separtely administered as "North Kirklees". No coincidence whatsoever that the lockdown was announced just before the start of Eid.
                                    Can't help with capacitive scales – not much experience. But maybe the screws were bottoming before the read head was fully secured, allowing it to float slightly & shortening the screws fully secured it ?
                                    Nigel B.
                                    #488471
                                    Ian P
                                      @ianp
                                      Posted by Bob Wild on 30/07/2020 23:27:14:
                                      We don't have too many psychics here so it should not be a surprise that no one explained how 'things' worked
                                      Certainly nothing wrong in mentioning brands or suppliers name.
                                      Now we have details of what the DRO is. Its a capacitive type (same as most digital calipers) operating principlesare easy to find on Wikipedia etc
                                      Does that mean that when the scale bar is in place the screws may have been touching the bar?
                                      Venting your spleen is a bit dramatic (as is your topic title!) Who was supposed to have this lesson?
                                      Bob
                                      Ian P
                                      #488585
                                      Roger Best
                                        @rogerbest89007
                                        frown interesting lesson Bob., So capacitive slides are as fussy as optical? I might start saving for the posh ones.
