Meshing with lantern pinions – Part B
Home Forums Clocks and Scientific Instruments Meshing with lantern pinions – Part B
  • #406110
    Sam Stones
      @samstones42903
      As a convenience, here is roughly where Thread Part A ended
      290-8---five-trace---cycloid-versus-lantern-pinions---02.jpgTo conclude, perhaps I should have carried the exercise to include deepening the meshing, i.e. crossing over the two PCD’s. However, I’m inclined to think that the results would be fairly obvious in that the teeth/leaves/pins would soon clash.
      Unlike the previous exercise where contact of wheel teeth and pinion leaf flanks produced slight changes of contact traces (especially the ‘On centreline and 0.1mm offset), the round pins of the lantern produced smooth curves. Similarly, as here …290-8pin-(cycloidal-&-lantern)---pressure-angle-comparison.jpg
      … the cross-overs of the pressure angles are less severe.
      Finally, and despite my own luck, only slight changes in depth from the theoretical (i.e. less than 1.0mm) suggest that depthing, at these sizes in particular, needs to proceed with extra care. No doubt for those with depthing experience, you will recognise how the meshing behaves. Too deep and there will be a gnashing of teeth? Too shallow, more gnashing?
      Links to both albums are here …
      Meshing with Cycloids
      https://www.model-engineer.co.uk/albums/member_album.asp?a=50467
      Meshing with Lantern pinions
      https://www.model-engineer.co.uk/albums/member_album.asp?a=50528
      Thanks for everyone who helped.
      Sam smile d
      Apologies if this mesh came unstuck.
      #3833
      Sam Stones
        @samstones42903
        Due to my zealous output, I have been ‘advised’ to split the original thread.
        #406120
          Blessed are the Lantern Pinions … for they follow the true path
          angel MichaelG.
          #406207
          Sam Stones
            @samstones42903
            Where would I be without your help Michael?
            Sam disgust
            I've removed my dark glasses, and can hear much better.
