A variable Lead threading attachment. Author Ted McDuffie
Home › Forums › Model Engineer & Workshop › A variable Lead threading attachment. Author Ted McDuffie
Viewing 25 posts - 1 through 25 (of 41 total)
  • #121427
    Brian Wood
      @brianwood45127
      Some help please with Mr McDuffies article which was published in MEW in the Autumn edition 1990, before the time I started taking the magazine.
      My interest stems from Theodore Clarke's artic;le in MEW 204 [ the current issue] which refers to Mc Duffies work as a reference; it would make useful background reading on what seems to be an interesting method of altering thread pitch.
      Can any of you help please with a back copy or similar?
      Thank you
      Brian
      #38181
      Brian Wood
        @brianwood45127
        Article in MEW ??? published Autumn 1990
        #121432
        Robin King
          @robinking15611
          If you've managed to log in to post this message presumably you can also access the digital edition, issue 2 on the last page of the digital listing – would that help?
          Robin
          #121434
          Brian Wood
            @brianwood45127
            Hello Robin,
            Thanks for the suggestion but don't I have buy into the digital issues first? And in any event I am missing the actual issue number to look for as well.
            I'm not being deliberately mean, I already pay for my copies at subscription rate
            Brian
            #121435
              If you have a paper subscription to MEW then you can view MEW back issues on line, if you get it from newsagent etc you can't.
              Its issue No2.
              #121437
              Brian Wood
                @brianwood45127
                That's very helpful Jason, thank you.
                Brian
                #121441
                Sub Mandrel
                  @submandrel
                  Brian,
                  You need to enter your subscriber number on your profile page before you can access your digital issues.
                  Robbo
                    @robbo
                    Brian,
                    If you're not a subscriber but an "over the counter" reader of MEW, I can send you a digital copy of the article.
                    Phil
                    #121488
                    Brian Wood
                      @brianwood45127
                      Gentlemen,
                      Thank you one and all for the sage advise. I do pay for postal subscriptions but I usually dump the wrapper which has the Sub. number on it; this time I need it!! Ah well, there's no rush, I now have the information I needed to retrieve that particular article
                      Phil. Thank you very much for your generous offer, it is greatly appreciated but I hope I can work the digital method satisfactorily. My suitably aged grandson lives in the USA so I shall have to muddle through; it doesn't come as easily to me as making swarf and failures.
                      If all fails I will knock on your door.
                      Thanks again to everyone
                      Brian
                      #121556
                      Robbo
                        @robbo
                        Brian,
                        Forgot to say in previous post that I have all the paper copies of MEW, so can just scan several pages into one file.
                        As my wife would say "silly old fool" I wish she wouldn't call me old!
                        Phil
                        #121565
                        Brian Wood
                          @brianwood45127
                          Hello Phil,
                          I get the same sort of disrespectful comment, it depends on the crime of course but "daft old bu**er" gets used for serious offences!.The 'old' bit does grate doesn't it.
                          Thanks again for your support if I need it.
                          Best wishes Brian
                          #121704
                          jacques maurel
                            @jacquesmaurel42310
                            I've published a "universal threading attachment" almost completely contained on a toolholder, based on Thales theorema, point E being fixed and BC being adjustable:
                            #121705
                            jacques maurel
                              @jacquesmaurel42310
                              This was in ME issue 4270 (march april 2006) general view:
                              #121976
                              jacques maurel
                                @jacquesmaurel42310
                                There are numbers stamped on the lever and charts are given so it's easy to cut any lead. On the photo (metric lead screw) one side of the groove is graduated for imperial leads, the other for module leads (for cutting single start worms). No change gear is needed, all cutting is from the standard gear box but the thread must be short (50 mm) read the article for details.
                                #122008
                                Gary Wooding
                                  @garywooding25363
                                  I don't take ME, so could you make details available on this forum, or maybe email to interested parties?
                                  #122100
                                  jacques maurel
                                    @jacquesmaurel42310
                                    The calculation is BC = 30/(p'/p-1) mm, p' being the lead to obtain and p the standard one.
                                    Ex for p' = 20 TPI (1.27mm) and p = 1mm, BC = 111 mm (position 2).
                                    The charts and graduations are here to help when setting the lathe for standard leads (imperial and module for a metric lead screw, metric and diametral pitch of an imperial one).
                                    Almost any lead can be obtained within the range of the lathe gear box.
                                    My attachment is quickly set up (contained on a toolhoder). Because for me the time for removing and resetting the top slide, is the same as the time for setting and resetting the banjo arm.
                                    Ex : chart for machining module leads from a metric lead screw:
                                    #122144
                                    Brian Wood
                                      @brianwood45127
                                      Hello Jacques,
                                      I have been busy elsewhere since my posting on 5th June, you have added helpful information and some detail to flesh out the story and extend the understanding a trifle. Thank you
                                      Gary Wooding
                                      If you want a copy of the Mc Duffie article that I started this thread with, send me a PM with your email address, I can now copy one to you.
                                      Brian
                                      #122350
                                      jacques maurel
                                        @jacquesmaurel42310
                                        With the universal threading attachment (and the others variable lead attachments) it’s possible to use the “Thread dial indicator”, so it’s possible to open and close the “Half nuts”,(as you are using a standard thread from the gear box). This makes thread machining far easier!
                                        It’s possible to work against a shoulder from left to right as described in this video:
                                        jacques maurel
                                          @jacquesmaurel42310
                                          This link will work :**LINK**
                                          #122357
                                          MICHAEL WILLIAMS
                                            @michaelwilliams41215
                                            Just a few simple thoughts :
                                            ? Increasing geometric error as linkage goes away from the all square condition .
                                            ? Correcting link , correcting slide or correcting cam .
                                            ? Analysis same as for pantograph and parallel motion mechanisms .
                                            MikeW
                                            #122368
                                            Sub Mandrel
                                              @submandrel
                                              But are the errors ever big enough to need this level of correction? Only for leadscrews or similar.
                                              A 1% error in an M6 thread would amount to about 0.05mm over the thickness of an M6 nut. Smaller than the production tolerance, and as good as a die-cut thread.
                                              jacques maurel
                                                @jacquesmaurel42310
                                                The purpose of this attachment is not to correct the lead but to use the standard gear boc leads for machining any odd lead, so no change gear is needed (only the standard gear box is used).
                                                Of course there is some geometric error as the linkage goes away, but for about 50mm long (short thread) this is negligeable (less than the lead screw error).
                                                #122394
                                                Ady1
                                                  @ady1
                                                  Will it do metric threads on an imperial lathe? Will the dial indicator work?
                                                  Edited By Ady1 on 16/06/2013 02:33:47
                                                  #122402
                                                  MICHAEL WILLIAMS
                                                    Hi Jaques and Neil ,
                                                    With representative proportions of device as in drawing positional error of tool is of order 0,4 mm when top of combining lever is offset 25 mm .
                                                    Whether this level of error matters depends on the kind of work that is being done and the fineness of thread being cut .
                                                    Regards ,
                                                    MikeW
                                                    #122405
                                                      Jaques, Thanks for the dual language titles on your video. I am learning some new French words.
                                                      I somehow missed the ME article in 2006 so am glad this came up. It looks very useful for old lathes where most of the change wheels have gone missing and there never were metric combinations anyway. The error shouldn't matter since I find most threads are at most only 2 nuts long.
