Some rough measurements using digital calipers
Duracell AA cell Panasonic Eneloop
Diam 13.91 to 14.30 (not truly circular) 14.18 to 14.45
Overall length 50.67 50.43
Main body length 48.80 49.17
Pos terminal 1.88 1.30
The plastic sleeve makes accuracy difficult as you get difference depending where exactly you measure, but the above are as close as I could get. Also had to be quick as the caliper were effectively shorting out the cell on a couple of the measurements.
So it seems they are both within spec apart from the diameter of the Duracell in certain orientations.
I'll try a few others.
Rob
Edit – Drat! The careful formatting didn't work – first figures are Duracell, second are Eneloop
Edited By Grindstone Cowboy on 26/07/2021 23:12:34
