WM18 – Broken it again :(
Home Forums General Questions WM18 – Broken it again :(
Viewing 25 posts - 1 through 25 (of 102 total)
  • #452720
    petro1head
      @petro1head
      Well I seem to have done it again
      This time was drilling a 22mm hole using low speed and all of a sudden the main RCD tripped.  Reset it and switch the mill on, nothing.  Replaced both fuses in the mill as both had blown.  Once replaced the motor fired up but sounded like it was sparking/arcing and would only turn at 250rpm no matter where the pot was turned to so I suspect the motor is broken, just wondering what test I can do before ringing Warco tomorrow?
      Also just wondering how much a replacement motor may cost?
      Edited By petro1head on 17/02/2020 17:38:37
      petro1head
        @petro1head
        #452727
        Journeyman
          @journeyman
          Well, the specification does say maximum drilling capacity 16mm, sorrycrying New motor price depends whether it is the old DC brush motor or one of the newer brushless variety.
          Edited By Journeyman on 17/02/2020 18:29:40
          #452732
            If you keep breaking it I would be looking at a new operator rather than motor or at least treat it as a hobby machine and don't expect it to cut like an industrial onedevil
            #452747
            KWIL
              @kwil
              I dio not think I have ever drilled a 22mm hole and I have a Bridgeport (amongst other machines).
              Much easier to start with what size drills easy and open up by boring (better accuracy as well).
              #452777
              Ady1
                @ady1
                Anything above 16mm should be bored on a hobby unit
                #452797
                  My lathe has a one horse power motor. I was drilling a 22mm hole last week, over 50mm deep. ~6mm pilot and in aluminium. But not even using back gear. No problem whatsoever.
                  I don’t have any short drills to do that on the mill (my large drills are tanged).
                  Seems like those motors don’t cut the mustard when the going gets tough.
                  #452802
                  Martin W
                    @martinw
                    The problem with DC brushed motors is that if they are not turning at a reasonable speed then the cooling fan is ineffective and they can overheat. To stop the Asian kit critics trotting out their usual mantra this is a problem with any motor that is dependant on cooling from a shaft mounted fan when it is run slowly and heavily loaded or as in this case looking as if it was overloaded.
                    Marttin
                    #452818
                      Agreed, likely overloaded, but nevertheless, I am confident my 3 phase motor would stand overload far better than these chinese offerings. Poor design – cheapness? – I reckon, for motors to go pop so easily. That is excluding operator abuse, of course, as I expect I could burn out my motor if I really tried.🙂
                      If these machines are so sensitive to overload, they should be fitted with a thermal cut out – many cheap welding sets even have one!
                      #452825
                      Dave Halford
                        @davehalford22513
                        You might need a power meter to keep one eye on as you work. Might help to prevent those overload death moments.
                        Either that or sell it and go light industrial with a Centec or Tom Senior etc
                        power meter
                        Edited By Dave Halford on 18/02/2020 09:33:49
                        #452830
                        Martin W
                          @martinw
                          If these motors are run within their specified limits and duty cycles then there doesn't seem to be a problem with overheating. Again it comes down to price and what people are prepared to pay for a machine. Like most products the features and to some extent quality will be set to meet the minimum standard that customers will accept at a given price.
                          There are many examples of same problem manifesting itself even on tools supplied by respected manufacturers, a classic example was using mains powered variable speed hand drills at low speed and high loads for extended period of time. Result the same problem damaged motors or hot hands plus magic smoke. I don't whether it is the same now but in the past welding sets used to be issued with duty cycle information to restrict self heating and prevent damage to the machine.
                          Martin
                          #452833
                            Posted by not done it yet on 18/02/2020 08:46:46:
                            Umm, not really comparing like-with-like. This is all to do with ratings and cost rather than design.
                            DC brushed motors are a good choice for machine tools, apart from the brushes. Before 3-phase most big motors were DC, and many still are.
                            But, as a proud WM18 owner myself, it needs to be emphasised it's a hobby mill, not rated or built for continuous hard work. The owner has to drive it appropriately and drilling a 22mm hole is asking for trouble – pulling lots of power at low RPM runs the motor outside it's comfort zone. Bit like a car, you might drop down a gear or two to accelerate whilst overtaking, but only a fool would drive from London to Edinburgh at 70mph in 2nd gear.
                            I've never overloaded my WM18, or broken a gear. I increase depth of cut and feed-rate on mine until I hear it distinctly working, but keep it short of labouring. The machine keeps going whilst being pushed hard, but there's no way of telling how distressed the motor, electronics, and gear train is. Better not to risk damage, by backing off a bit. Captain Kirk always gets away with ordering Scotty to red-line the engines. In the real world the Enterprise would end up stopped and smoking on the hard-shoulder and have to be towed to a garage. Captain Kirk would be dismissed the service in Series 1 for wrecking a star-ship against professional advice!
                            Edited By SillyOldDuffer on 18/02/2020 10:16:52
                            #452839
                            Martin W
                              @martinw
                              Dave H
                              While the use of a power meter might give some indication of the instantaneous power and total power being consumed it is far from ideal and can lead to a very false sense of security. Primarily this type of digital power meter is designed to measure sine waveforms, as one would theoretically expect to be supplied by the energy company, and usually makes a good stab at it plus or minus a few percent.
                              However when the measured waveform deviates from a a near sine wave then the readings can be grossly inaccurate. This can happen when these meters are used to measure the power being absorbed by a phase switched load as the load current is now a chopped up part of a sine wave. Even what are supposed to be 'True RMS' digital meters have a limited form factor for which they are accurate.
                              The main problem with these and similarly cooled motors is that when run slowly the cooling becomes very inefficient couple that to being fairly heavily loaded and it spells problems. The current is going to be high, as are the I2R (I squared R) heating effects with limited cooling. I suppose a fairly good analogy would be using a car with the cooling system blocked off and towing a heavy trailer up a long and steep hill. Frequent stops to let it cool down and all would be fine but try it in one go and the engine would soon emit a different type of magic smoke irrespective of build quality.
                              The use of a Power Meter could be a good idea if they were anywhere near accurate when used under these conditions at least one could monitor the total power being used and set a safe maximum time v power limit.
                              Cheers
                              Martin
                              Edit as post crossed with S.O.D. Dave's post
                              Edited By Martin W on 18/02/2020 11:19:10
                              Edited By Martin W on 18/02/2020 11:20:13
                              #452842
                              Jim Nic
                                @jimnic
                                To answer the OP's question I can advise that 3 years ago I foolishly cooked my lathe motor in a similar way by cutting a large diameter bar of unknown, but tough, steel at too low a speed for too long. The resulting lack of cooling made the motor far too hot to touch even 15 minutes after it gave up the struggle. The cost of a replacement from the machine supplier was close to £150.00.
                                Jim
                                #452863
                                  Some of "these" machines do have an overload trip, my mill certainly does as I have tripped it a few times so should not assume that all DC motored mills don't have this feature.
                                  I stalled the lathe a couple of times the first time I went to cut a 9 or 10" iron flywheel, soon learn what it's limits were and adjusted my methods to suit and have not had issues since and that was 10-12yrs ago. I've said it several times on here that they work better run a bit faster and with a shallower or finer cut in the end you get the work done in a similar time. They are quite capable if treated with respect and as hobby machines not treated and used in the same way as heavy geared or belted industrial ones.
                                  For example the typical old advice was to engage back gear and take a deep cut to get under the skin of a flywheel or loco wheel casting. I'd be doing a 9-10" dia flywheel at 3-400 rpm and taking 0.5-0.75 deep cuts with carbide that can handle the speed and not bothered by the skin.
                                  Same for holes I'll work my way up in 3mm increments starting at 6mm and then finish by boring. drills can be wound if at a good feed rate not having to use both hands on the tailstok to force them into the metal as per a recent thread so not a lot of time difference and less strain on the motor and electronics
                                  #452892
                                  Ron Laden
                                    @ronladen17547
                                    I am relatively new to machining but one thing I have learnt is the limitation of my machines. I have an elderly Warco 918 lathe and a SX2P mill which are both hobby machines and I try and keep within their capability and quite often well within at the expense of an increase in time/number of cuts etc.
                                    I get good results from both the mill and the lathe and they are quite capable for their size providing what I ask of them is realistic, expecting too much of them especially on a regular basis I think is just heading towards problems and breakages.
                                    Just my two penneth anyway.
                                    Edited By Ron Laden on 18/02/2020 16:35:02
                                    #452940
                                      Well I, just for the fun of it, just drilled a hole about 30mm deep with a 22mm drill into some non-descript steel after piloting with a 6mm drill.
                                      One horse power motor, no problem at all. Lathe only slowed when thick continuous spirals were being turned out – OK with thin continuous spirals. This was in normal speed range, not back gear.
                                      IMO, a 1 1/2HP motor should be up to the job. Methodology, and edge on the drill may have been factors. Otherwise these motors are just not up to the job. I wonder whether the motor rating is input or output. Anyone know? If it is input, what is the motor efficiency?
                                      Seems like it may have been a very expensive hole!
                                      #452960
                                        Would be nice to know what lathe it was. How does your mill cope with the same size hole as the OP has broken his mill this time, broke the lathe last month.
                                        You need to remember these DC motored vari speed machines are seldom geared so motors don't give their full rating at slower than full speed unlike your (assumed) geared/belted machine. Even then what the motor puts out can differ depending on how the torque settings have been set on the board and by differing boards
                                        Also read yesterday of one of our members stalling his Bridgeport and he does know what he is doing.
                                        This is the only illustration of what I have been saying. A Brushless direct mill first running an HSS slitting saw at the calculated book speed of 100rpm and if can't do it. Up the speed to 210rpm and it has no problem though a slow feed is needed. By contrast the X3 with just a high/low gear box did the same cut at 100rpm in low range and has a lower wattage brushed DC Motor
                                        Edited By JasonB on 19/02/2020 07:04:59
                                        #452961
                                        Ian Parkin
                                          @ianparkin39383
                                          Petro1head
                                          I do have a motor and speed control board that I took off my wm18 that you can have for a good price
                                          all working
                                          i fitted a 3 phase and vfd to mine
                                          #452965
                                          Tony Pratt 1
                                            @tonypratt1
                                            Don't think the OP mentioned a pilot drill, makes a hell of a difference.
                                            Tony
                                            #452969
                                            Paul Lousick
                                              @paullousick59116
                                              Drilling a 22mm hole on a lathe or mill with a one horse power motor should not be a problem if it is fitted with a gearbox or belt drive speed reduction as the motor is running at full speed and the internal fan is cooling at 100% but if using a variable speed motor, at a slow speed the fan air flow is reduced and can lead to overheating.
                                              Even though the DC motors have good torque at low speed it is less than what you would get a reduction drive system. The WM18 mill has a 1.5kw variable speed motor and is only rated to drill a 16mm hole. My RM-45 mill only has a 1.1kw fixed speed motor and gearbox drive and can drill up to 31.5mm holes. I used to have a Seig SX3 mill with a 1kw motor and to drill bigger holes, up to 36mm, I used a rotabroach instead of a twist drill with no problem.
                                              Paul
                                              #452979
                                              Mike Poole
                                                @mikepoole82104
                                                If you use a variable speed motor to control speed then don’t forget that the power is also reduced. A 1hp motor only produces that power at full speed, at half speed it will reduce the power by half (roughly).There are calculations for material removal rates and the power required. A large drill will need to be run at a suitable slow speed but it still wants power to cut. As Jason says he adjusts his cut and speed to accommodate the reduction in power. Speed reduction by belt drive and gears has the advantage of keeping full power (ignoring losses). Electronic drives do fall short when larger diameters need slow speed but still want full power for a reasonable material removal rate. VFD conversions of conventional lathes have the benefit of retaining the mechanical speed selection so for larger diameters the back gear can be utilised so the speed control can be run at a high speed and thus develop full power to effectively multiply the torque available for cutting. Low speed high power exposes the compromise of electronic speed control.
                                                #453000
                                                  Do the purveyors of these machines point this out to prospective purchasers? NO, THEY DON’T! There is inter-company competition to attract the buyers with as much cheap hype as possible, this being just one facet.
                                                  Nobody(?) runs their machine at highest speed, at the chuck, all the time – unless the spindle speed is lacking (mine is only 1750 which is ‘slow’ and plain bearing machines are even slower). Carbide tooling is not best served at low speed, of course.
                                                  Not a lot different to band saws, which might appear to have twice the power, but are really no better than the ones which actually provide half the output power.
                                                  Little different to the compressors which, to some, appear to be far more efficient (by quoting ‘air displacement instead of the far more useful ‘free air delivery).
                                                  Unsuspecting punters are often being hoodwinked into buying machines that are not quite what they think they are.
                                                  There is one well recommended seller (by forum members) that does not, at least, over-hype their machine power by over-rating the drives. There are likely quite a few that do.
                                                  Years ago, small stationary engines from one manufacturer were rated differently to competitors. They eventually had to reduce their ratings because they got so much flak from dissatisfied owners – that their engines were ‘gutless’ – and their reputation suffered as a result (they reported ‘flash’ output, not a continuous output).
                                                  This is likely why ‘old iron’ is often better than buying new. OK if the buyer is aware and able to make fair comparisons. Not so good for the new starters, with no basic knowledge of this advertising hype. Mechanical wear is another problem for the ‘non-mechanicals’, of course.
                                                  Just ask any myford owner how many motors the machine has gone through in its lifetime of 50, 60 or 70 years.🙂
                                                  I’m still awaiting any reply on whether the figure quoted for this machine is actually to the motor or usable power out – or even power to the lathe, not necessarily to the motor, even. My current lathe has had a motor change (guessing simply from single phase to three phase) and my previous was likely still on its original (the direction change-over switch was a three phase type and certainly more than thirty years old when I bought it) and the instruction manual did warn about reduced motor life if started on a high speed setting, instead of reducing the speed before switching off. My first lathe only had its original motor (although its position was not ideal re magnetic swarf collection&#128578.
                                                  Old is not always good, but is almost certainly more reliable.😉
                                                  #453004
                                                  Circlip
                                                    @circlip
                                                    Ah but NDIY, you're not playing fair. Not everyone has the intelligence to select an appropriate cutting speed when using a lathe headstock equipped with GEARS. Much more lucrative to have a ready market with replacement Motors and elecfronic speed controls. Far more exciting to get it wrong and watch the smoke waft about and then try to fault find.
                                                    Regards Ian.
                                                    #453005
                                                      Posted by not done it yet on 19/02/2020 12:03:09:
                                                      The fact they say "max drilling capacity 16mm" is quite clearly giving the limit of what the machine should be expected to do.
                                                      Other suppliers have ratings such as Craft/hobby/trade or model engineer/engineer and a lot state hobby use only or non production runs etc.
                                                      Sieg know that some people won't read the instructions so also put the max capacity on the front of the mills head, you can't point it out much more obviously than this. Unfortunately there are still those who know better and that is why we tend to get more posts by people with problems with their machines than by those happy with then and that distorts many peoples views of these machines
                                                      I would say Warco list Input to the motor not output from what has been said here over the years.
                                                      Still like to know what lathe you were using?
                                                      And once again I will point out that the WM18 is a mill as you still seem to think it is a lathe.
                                                      Edited By JasonB on 19/02/2020 12:30:30
                                                      Edited By JasonB on 19/02/2020 13:18:36
