About tap & die’s
About tap & die’s
Home › Forums › General Questions › About tap & die’s
Viewing 25 posts - 1 through 25 (of 42 total)
  • #25606
    Karl Fuller
      @karlfuller66495
      #325488
      Karl Fuller
        @karlfuller66495
        Hello guys & gals
        I am just learning about tap & Die never done it before and would like to ask some questions before i start ,But for me its very confusing even after looking at charts online i still am not sure which size drill bit i would need so i can make M18X2.5 thread .
        And what size bar would i need in order to make a thread on that to fit the hole with new thread on from the M18X2.5 ..
        Thank you ..
        Karl
        #325503
          As a simple rule of thumb for metric threads you can just subtract the pitch from the nominal dia so 18 – 2.5 = 15.5mm drill. The hole can be drilled a little larger depending on what loadings you are putting on the fixing as that makes tapping easier.
          The diameter of the rod is even easier as that is the same as the thread size so on M18 you would need 18mm dia rod.
          J
          #325512
          Paul Lousick
            @paullousick59116
            Lots of reference tables for drill sizes on the internet.
            This a link to one: **LINK**
            #325516
              I usually consult 'engineering toobox dot com.
              There it quotes 0.614 x pitch.for metric threads, so 1.228 x pitch reduction, but that would not leave anything to be cut at the internal crests, so JB's rule of thumb is good.
              As a point of note, 18mm coarse 2.5mm pitch) is not listed as a 'standard' size on that site – only 16 and 20mm. 18mm is quoted for 1.0, 1.5 and 2.0mm pitches. But if you have a tap and die of that size, they obviously exist!
              #325518
              HOWARDT
                @howardt
                The diameter stated, in this case 18mm, is nominally the dia of the shaft to be threaded. The actual diameter is slightly less than nominal due t the rounded top or crest of the thread. The hole diameter to be threaded is the core diameter of the thread, this being the nominal diameter 18mm less the pitch of the thread, roughly. As previous stated this can be used as the hole drill diameter but may result in a tighter hole which can cause breakage of the tap. Drill tap tables are numerous on the web, with reccomendations for softer and tough materials. You will soon get the feel of the hole sizes which suit your work.
                #325521
                Mick B1
                  @mickb1
                  Be aware that this is a substantial thread for manual tap & die work on steel. I did some 3/4" BSW on EN8 not long ago – not far off the size you're doing, and I was pretty knackered by the end of it! laugh
                  #325547
                  larry Phelan
                    @larryphelan54019
                    Is there not a book called "Zeus" still around these days? If you dont find what you need there,it must be rare indeed ! Well worth buying,although I got mine for nothing !
                    Great read !
                    #325549
                    jimmy b
                      @jimmyb
                      M18 x 2,5 is standard size
                      #325558
                      Martin Connelly
                        @martinconnelly55370
                        Zeus books are still available from Buck and Hickman and probably other sources.
                        Martin C
                        #325562
                        Mike Poole
                          @mikepoole82104
                          Using a tapping compound will help in your endeavour, my favourite is Trefolex for steel. It is important to keep reversing the tap to break the cuttings that are being made if you don't you risk jamming the tap. When getting the tap started keep checking it is square until it is well under way. Make sure you have a nice cold beer waiting for you after you have finished, you will have earned one!
                          #325566
                            18mm is not that big. Just need a handle size commensurate with the job. Work done will be the same whatever the handle size, but longer ones reduce the power needed. I think Abom was tapping about an inch and a quarter, handraulically, on a recent video -but I maybe he has enough beef to swing most handles!
                            #325574
                            John Haine
                              @johnhaine32865
                              Posted by not done it yet on 05/11/2017 13:47:07:
                              Do you mean…
                              Work done will be the same whatever the handle size, but longer ones reduce the force needed. ?
                              #325576
                              Karl Fuller
                                @karlfuller66495
                                Wow so many replies wasn't expecting that 😀 Thanks all .
                                So is that what M18 mean 18mm ?
                                So 15.5mm drill bit for the hole,
                                And 18mm rod bar to match, Then add thread from M18 2,5 ? that will reduce the size to 15.5mm with thread is that right ,Seems so far apart in size ,finding this hard to get my head round ,I will get there i hope .
                                Oh only have 15.5m rod at the moment will need to order some 18mm then ..
                                #325579
                                Oldiron
                                  @oldiron
                                  The 15.5 will be the root of the thread. The crest will be around 17.5 when finished according to an 18mm bolt I have in the drawer.
                                  #325581
                                  Trevor Drabble 1
                                    @trevordrabble1
                                    Karl , sent you a PM.
                                    Trevor
                                    #325585
                                      If you must, but work done will be force multiplied by displacement (mustn't say distance, but practically the same here), but if the handle is twice the length only half the rate of doing work would be required to turn it at the same speed (not angular), albeit at half the rate of displacement. Basically, as a theoretical example, a seven stone weakling may actually be able get the job done (at a lower rate of doing work), with a longer handle while a 14 stone strapping lad/lass could do it with the shorter handle. But it might take twice as long for the weakling, with both working at the same % capacity of their power output (if one was 'twice'as strong as the other). OK?
                                      Sort of, but only a bit over half of the material will be removed, the other half is needed to engage with the other thread.
                                      19mm is likely a more common (so cheaper) size. Virtually the same as 3/4".
                                      #325587
                                        Posted by not done it yet on 05/11/2017 15:54:49:
                                        But then the OP will need to find a lathe to reduce the dia to 18mm, far easier to buy 18mm from the start which is a stock metric size.
                                        #325651
                                          Jason has summed it up.
                                          Tapping size for metric is nominal – pitch.
                                          Material for male thread is nominal size of thread.
                                          If you make the tapping slightly larger, there is less engagement, and so reduced strength.
                                          If you make the diameter of the material for the male thread smaller, again, the engagement decreases, and so does the strength.
                                          Obvious if you think about it, but don't go mad a 17mm tapping drill WILL mean a very weak thread.
                                          A 15.7 won't do any real harm, probably, unless you plan to use it to winch Queen Elizabeth 2 up a dry slipway!
                                          But this means that a slight decrease in engagement will not automatically result in a stripped thread, (unless you put a scaffolding pole over your spanners).
                                          Go for it!
                                          #325657
                                          Anonymous
                                            Something else to think about – I did an experiment with M4 threads; with a high tensile bolt in aluminium 6082, with 50% thread engagement, the bolt broke first. I normally aim for around 65-70% thread engagement.
                                            As an aside hand taps extrude the material to a small extent so you shouldn't drill for 100% thread anyway.
                                            #325665
                                              Andrew,
                                              How many threads were engaged for the bolt to break, rather than stripping the threads. Presumably the bolt was not screwed down tight with head to aluminium, or bottomed out? It might not be the same story for a man-sized bolt like 18mm!​smiley
                                              #325670
                                              duncan webster 1
                                                @duncanwebster1
                                                Thread strips along a line (actually cylinder) of equal shear strength in male and female. Male is usually made of stronger material, so the cylinder diameter is bigger than the mean diameter. Increasing the size of the tapping drill within reason has little effect on stripping force but it does increase the interface pressure, so it can't be taken too far. Root diameter of M18*2.5 is 14.7m so 15.5 tapping drill gives 76% engagement. I'd happlily use a bigger drill, 16mm would be 61% which might be a bit low, depends on the job and what load it might see.
                                                However to digress, or even get back to the OP's original post, M18 is a big thread to learn on!
                                                #325671
                                                Chris Trice
                                                  @christrice43267
                                                  Tubal Cain's book on threads is very illuminating. The reason nuts can be plain steel while the bolt is high tensile is because the threads are in compression on the nut (stronger basically) and in shear on the bolt. The other interesting thing was demonstrating the benefit that only a small increase in tapping drill size (over the Zeuss table figures) can dramatically reduce the torque needed to cut the thread and in turn reduce the chances of breaking the tap. The point was also made about how tapping a hole involves an element of extrusion. This was illustrated by attempting to pass the original tapping drill through the tapped hole and finding that the hole had closed up.
                                                  #325677
                                                    I did a similar experiment at the same time as Andrew and stripped the female thread, think I used M8 Imported hex screw and 10mm black bar,. As I said all depends on what the fixing is expected to do as to how much you can play with sizes.
                                                    Edited By JasonB on 06/11/2017 07:29:49
                                                    #325686
                                                    D Hanna
                                                      @dhanna35823
                                                      The OP should be right now but looking through some info on percentage of thread engagement it seems a bit out. As many of us started out in our early work with BSW and BSF I'll start there.
                                                      If we look at the BSW thread form, we will note that both male and female form is the same which means (disregarding working clearance) that if the nut has the full depth of 0.6403P and likewise the bolt has full form we have 100% engagement. However, if we use the workshop formula of OD-Pitch for drill size, then the depth will be only 0.5/06403 = 78% hence the quoting of around this figure for all thread forms. How does that sound?
                                                      Now moving on to Metric and Unified thread form (they have the same thread form), the basic thread form depth and maximum engagement of 100% is 0.541P. Note that the female thread has the root radiused to clear the OD of the male thread (see more on this below) Once again, using our OD-P formula, the engagement here will be 0.5/0.541 = 92%, much more than some are quoting. With a bit of metal flow we are most likely at around 96% causing much more load when hand tapping and cause of some tap breakages Maybe this is brought about by some thinking that the nut has the same thread depth as the male thread of 0.613P. NOTE: this figure is for the max male thread depth. Minimum is given as 0.591P. These figures give clearance between minor dia of nut and root of male thread..
                                                      Another thing noticed is the quoting of OD on some fasteners being well undersize. Yes this has an effect on the amount of thread engagement depending on how much under it is but has nothing to do with sloppy thread fits. The fit is controlled by the difference in effective diameters.
                                                      As I've mentioned above re the root of the female (nut) thread being radiused to clear the screw OD, has anyone taken the time to measure a tap OD? an M10 x 1.5  will measure around 10.2mm. Some of this is used by the clearance for the male thread. The crest of the tap thread is radiused 0.72P if my memory is correct. The height of that radius will be 0.36P. Add this to the 0.541P and we have thread depth of 0.577P in the nut IF THE BORE IS EXACT.
                                                      Please note that my post isn't aimed at teaching anyone to suck eggs, just to point out some facts about the threads and maybe help beginners/hobby workshoppers understand why we do things.
                                                      Edited By D Hanna on 06/11/2017 09:48:33
