I made mine a while ago…
…but I'm currently investigating the Wimberley which I think has some advantages particular as a right hand hogger of material.
It doesn't need to hang below the bottom of the bottom of the tool-holder and the flank wear of the cutting bit is naturally ground off in sharpening.
If you get any flank wear with the tangential toolholder you sometimes need to grind off quite a lot of the tool tip to get below it.
HTH
Jon
Edited By Jon Gibbs on 05/09/2016 10:44:01
