Shaper Vice?
Shaper Vice?
Home Forums Workshop Tools and Tooling Shaper Vice?
  • #19654
    Andrew Tinsley
      @andrewtinsley63637
      #456460
      Andrew Tinsley
        @andrewtinsley63637
        I remember an uncle telling me that a shaper vice was different from those used on a milling machine. This was many years ago and I cannot remember what the crucial difference was. Perhaps a lower profile?
        Any information would be welcome, to help my filing memory!
        Andrew.
        #456462
        Andrew Tinsley
          @andrewtinsley63637
          Sorry! I did type failing memory! But must have not pressed hard enough.
          Andrew.
          #456466
          Joseph Noci 1
            @josephnoci1
            I believe the shaper vice screw is under tension while a 'normal' vice screw is under compression – I have a shaper and such a vice and I believe the theory is that when planing in the screw axis with a compression screw, toward the screw, the cutting force may work against the compressed screw, thereby releasing the vice jaw pressure and allowing the work piece to move.
            I am not sure why there is a supposed better chance of compressing the screw as opposed to stretching it if under tension..
            Joe
            #456476
            Anonymous
              Posted by Joseph Noci 1 on 10/03/2020 15:21:48:
              I believe the shaper vice screw is under tension while a 'normal' vice screw is under compression….
              Well, so it is, on mine at least:
              The nut behind the fixed jaw is in fact two nuts locked together,, and is clearly where the reaction takes place in contrast to the weedy collar at the other end. Generally I'd have said that shaper vices tend to be brick built outhouse style compared to machine vices of comparable capacity. Not sure if it's odd but the vice pictured has a square thread rather than Acme.
              #456477
                I think the point is the fixed jaw is at the front of the machine, so the cutting force is into it. Then when you think about getting the screw handle to be also at the front for convenience of operation you end up with the moving jaw having to be pulled towards the front – hence screw under tension.
                #456478
                  Or is it because a rod in tension can take a lot more force than the same rod in compression? Compressed rods are likely fail by kinking, but will go all the way to their breaking point when stretched.
                  #456490
                  Joseph Noci 1
                    @josephnoci1
                    Posted by Bazyle on 10/03/2020 16:11:22:
                    Do you mean 'pushed towards the front' ? ( by the shapers stroke)
                    Also, I would like to see the typical large milling vise screw fail by kinking when used one the shaper!
                    Edited By Joseph Noci 1 on 10/03/2020 17:28:52
                    #456493
                    Andrew Tinsley
                      @andrewtinsley63637
                      Thank you all,
                      I shall now look for a small vice for my shaper. Could be a long wait!
                      Andrew.
                      #456497
                      mgnbuk
                        @mgnbuk
                        Seems nobody told Boxford about the need for a "special" shaper vice :
                        Original swivelling vice on an 8" Boxford shaper – not had anything come loose while using it. Maybe the machine is not capable of stressing the "conventional" vice used ?
                        Nigel B.
                        #456499
                          Posted by Joseph Noci 1 on 10/03/2020 17:27:48:
                          Doesn't seem likely does it, but is that only because vice screws are short and fat? I feel an experiment coming on!
                          1. Can I detect an increase in the diameter of a machine vice screw when it's compressed rather than undone?
                          2. Does a machine vice screw bend as it's tightened?
                          Not sure how to measure either sensitively. Hey ho, time for a think.
                          Another thought, does a shaper put more force on the workpiece than other types of machine tool? I'd have thought not. In which case my kinky idea is unlikely.
                          John Olsen
                            @johnolsen79199
                            I just took a look at my shapers to see what is what. The 18 inch Alba has the arrangement that puts the screw under tension. The 10 inch Alba does not, the screw will be under compression. Those are both original vices. The Ammco shaper does not have an original vice, but I have the drawings and that would put the screw under compression.
                            I think the main feature of a shaper vice is that they are usually low profile.
                            I don't think that the cutting forces on a shaper are any higher than with anything else, the only point you should watch is when the cutting force is along the vice jaws, when it may move the job. A piece of paper between the jaws and the job is enough to prevent this.
                            Joseph Noci 1
                              @josephnoci1
                              Now that's a vice…
                              #456561
                                Posted by Andrew Tinsley on 10/03/2020 15:01:15:
                                Andrew.
                                You could easily simply correct that mistake by using the ‘edit’ option?
                                Seems nobody told Boxford about the need for a "special" shaper vice ….
                                Yes, others too. The screws of some low-profile vises on the likes of Drummond were in compression. There is a securing bolt, tightened down, after securing with the item with the jaw screw, on the Drummond vise.
                                #456566
                                thaiguzzi
                                  @thaiguzzi
                                  Posted by John Olsen on 11/03/2020 02:35:02:
                                  This.
                                  +1.
                                  #456573
                                  Clive Foster
                                    @clivefoster55965
                                    I suspect the screw usually being in tension for shaper vices was more a case of following the way its usually done than the result of careful mechanical analysis. Somewhere during the early development process screw in tension was a feature of shaper vices that were known to work well and, therefore, became popular so folk stayed with what was considered a good design. Most especially if some attempts with screw in compression were found unsatisfactory. Even if that were due to reasons other than the screw arrangement.
                                    The generally low profile trend may have influenced things too.
                                    Back in the day many milling vices with screws in compression had the screw mounted externally pushing against the moving jaw. Usually fairly high up to give some anti-tilt effect. Seems that might have been a less costly way of making a vice albeit slightly less strong and inherently a little taller. So perhaps the underslung, screw in tension, arrangement also signified a better quality and therefore worth paying more for vice.
                                    Far as I can see there is no engineering reason why the cost of making screw in tension and screw in compression vices should be significantly different. But if you can charge more for one type that is the type that will get made. Heck if you could convince the factory owners to pay more for pink ones everything would be painted pink and shop floor groans about the new stuff being too girly ignored.
                                    Shaper and planer cutting forces are continuous so may well take more withstanding than the more intermittent cutting loads of the successive teeth of a milling cutter. Could well be larger in practice too. A big shaper or planer can take seriously hefty cuts. Even if it can't match a big horizontal mill with a nice set of ganged cutters for sheer speed with which it buries you in chips.
                                    #456580
                                    IanT
                                      @iant
                                      A low/wide profile – which most importantly includes the rotary base. Many of the small 'milling' vices currently available are relatively tall and often just have two fixing 'slots'. The Atlas vice has a bolt-down hole at each corner of its square base, making it both stable & very secure.
                                      The Atlas vice does have the screw through the back of the fixed jaw, so work is held in tension. Given a choice, I think this is preferable. The Shaper exerts a lot of side cutting thrust on the work, with cutting being interrupted on each stroke – so using a low, squat vice makes good sense but they are hard to find
                                      IanT
                                      Edited By IanT on 11/03/2020 10:02:32
                                      #456582
                                        If the handle of the vice is pointing away from the ram, (It would be difficult to have a conventional vice sited so that it points towards the ram ) on the normal, outward, cutting stroke, the screw of the vice will be under compression.
                                        The action of clamping the work will subject it to compression, anyway.
                                        You could mount one of the Precision Vice, Type 2, as sold by Arc Euro. On this, the cutting forces are resisted by a round bar clamped into a slot. In this, the clamping screw is in tension, since it is pulling the bar into the slot, but not subjected to cutting forces.
                                        Since it will see little use, and would cost more than I had paid for my Adept No.2 Shaper, I made a cheap, soft, and probably not very precise, version out of whatever material happened to be lying about.
                                        How it was made is shown in the article in MEW 290
                                        #456587
                                          I just use a milling vice…
                                          But my tiny Adept shaper isn't going to stress it much.
                                          Andrew Tinsley
                                            @andrewtinsley63637
                                            NDIY. I did not have the opportunity to edit the post. For some strange reason, about 50% of the time, there is an edit option available after one has posted. For the other 50% of posts, it isn't there.
                                            Perhaps you could explain this phenomena.
                                            Andrew.
                                            #456592
                                              Best ask Neil/Jason, I would have thought, not me. My post ALWAYS have an edit option. I use it quite a lot.
                                              I know this forum has some quirks, but never come across one quite like this.
                                              #456595
                                              mgnbuk
                                                @mgnbuk
                                                The Edit function is time limited – a 20 or 30 minute window from posting IIRC, then the function is removed.
                                                Nigel B.
                                                #456600
                                                Andrew Tinsley
                                                  @andrewtinsley63637
                                                  Hello Nigel,
                                                  Yes I am aware of the time limit. I should have made clear that the edit function isn't there when the post is made! Sometimes it is and sometimes not. If I make a mistake I always try to edit it out, but if the edit button isn't there at moment of first posting, then one is somewhat stuck!
                                                  Andrew.
