Workbench drawers
Workbench drawers
Home › Forums › Workshop Tools and Tooling › Workbench drawers
Viewing 25 posts - 1 through 25 (of 34 total)
  • #18558
    ChrisB
      @chrisb35596
      #303753
      ChrisB
        @chrisb35596
        Hello, I'm at a loss trying to figure out the best way to construct drawers for a workbench and two machine stands. Basically I want three shallowish drawers at the top (10cm deep) and a single deeper drawer (23cm deep). I'm no carpenter so I have no idea how to go about doing them. My thoughts were plywood sides, fronts and backs on telescoping rails and a steel or aluminium bottom, ( if I went for plywood bottom I'd loose more space because of the thickness)… am I on the right track? Ideas and advice are most welcome.
        This is what I have in mind, to explain myself better.
        #303755
        Frances IoM
          @francesiom58905
          MDF is easy to use – 18mm MDF for sides screwed + glued base with extendible runners (eg from Screwfix) will take considerable weight (eg my granite surface plate sits in one such drawer – make a small jig (as used in making picture frames) to keep corners square – careful measurement or use a sawbench with guides. Often the larger B+Q branches will sell MDF offcuts suitable for sides at 50p or so (or even give it away ) just cut all drawer sides at same saw settings to guarantee easy square frames – consider use of the various plastic box inserts sold for the 'really useful' range of boxes
          #303761
          Paul Lousick
            @paullousick59116
            I used plywood for the sides and bottom of the drawers and re-inforced the corners with 16g steel angle. The angle was pop rivetted to the plywood. Steel washers used as a backing to prevent the rivets pulling thru the plywood and the draw slides rivetted to the steel angle.
            These drawers are light and strong and will extend completely out of the cabinet on the telescopic slides.
            #303766
            Joseph Noci 1
              @josephnoci1
              Why not fully from 2mm Aluminium, as I did here:
              Joe
              #303771
              ChrisB
                @chrisb35596
                Posted by Joseph Noci 1 on 23/06/2017 07:21:23:
                Joe
                Nice! but that would take me a couple of ages to complete! Besides I have three benches to do on which I still have to mount the lathe and mill, so the sooner I'm over and done with the better so I'll start making some swarf!
                Was not considering MDF as I thought that was a bit soft for a workshop environment and has a tendency to swell in contact with water so I was heading to marine plywood or some cheapish solid wood. The drawer width being 63cm and bearing in mind that some heavy items will be stored in these drawers (lathe/mill tools) would a wooden base be sufficient?
                #303772
                  These ones are 18mm FE plywood sides glued and biscuited with a rebate cut in the bottom and 6mm MDF bottom screwed and glued in place on full extension runners.
                  These ones are a mix of ply and MDF sides as I was using up offcuts, again 6mm bottoms screwed on but no rebate.
                  The Bisley draws you can see on teh left are good for small cutters etc.especially when you can get them for about £10 eachsmiley
                  #303774
                  Frances IoM
                    @francesiom58905
                    you use floor varnish on the MDF once the drawers are complete – two coats will give excellent protection from oil + water – MDF is also dimensionally stable whereas natural wood needs allowance to be made for changes due to moisture + temperature
                    If you are making them to go in an outside shed then be wary of metal drawers that can act as condensation hideaways
                    #303777
                      We posted at the same time. Not all MDF is soft and prone to swell. I almost only use MR (Moisture resistant) MDF for work, not only will this resist reasonable short term wetting and not be affected by humidity it is about 50% denser than Standard grade MDF and even more so than DIY shed MDF.
                      As with all MDF boards be careful when screwing into the edge, pilot drill and use suitable carcase or MDF screws.
                      As Frances says a waterbased floor varnish is easy to apply and hardwearing, having said that none of my draw sides are sealed. The lathe draws have 6mm Melamine faced MDF but the blue ones are just bare MRMDF.
                      #303778
                      Perko7
                        @perko7
                        Most flat-pack kitchen cupboard & drawer units are made from water-resistant MDF and seem to last quite well. I usually scout around for used kitchen units from houses that are being renovated. With a bit of modification they work quite well, but sometimes need new drawer runners.
                        #303779
                        richardandtracy
                          @richardandtracy
                          Whatever you do, DON'T use chipboard. If there is high humidity through whatever reason, the chipboard will slowly sag under the weight of tools. In time, even in a dry workshop, chipboard will sag anyway, but humidity speeds things up.
                          I do tend to use pallet planks run through a thicknesser, leaving the finished thickness around 19-20mm. This is thick enough not to bend under a reasonable load, and I can get pallets for nothing so it's a good supply of raw material at a price I'm prepared to pay. Mind you, my workshop could not be accused of being 'pristine' like some of those here. Last night I sawed enough firewood to create a bucket full of saw-dust, so with it being a multi-purpose shop it'll never be as clean as some of those photographed above.
                          Richard.
                          #303783
                          pgk pgk
                            @pgkpgk17461
                            When i made my shed storage system it was all mdf.. and apart from some temporary hold on the base units it was all glued with brown glue and sash clamps rather than screws into mdf ends.
                            For the drawers i made up a simple jig – lines on a baseboard with DIY angles for the boards to butt against and triangular wedges (like adjustable parallels) one of the pair screwed down and the other tapped in as necessary. The 6mm mdf drawer base was also glued on and weighed down with a 10L paint can. I had a bunch of them stacked like a pagoda and then tidied everything up with a ball-bearing router bit and yacht varnished.
                            I've had bad experiences with cheap runner systems and too mean to buy the expensive ones so stayed with simple timber runners and wax.
                            #303785
                            ChrisB
                              @chrisb35596
                              Thanks gents, lots of useful advice as always – good enough to get me started in the right direction. Will have a look at the local timber shop to see what's available.
                              #303804
                              Spurry
                                @spurry
                                My version of storage is covered by commercial trays of many sizes. I find it much easier to pull out the 'drawer' entirely and place it on the floor or bench-top to access the contents. The individual carcases are made from mdf and just knocked together with a rubber mallet, and are free-standing.
                                #303821
                                Gordon A
                                  @gordona
                                  Steel sides and runners are available on "The Bay" at reasonable prices. You just have to provide front, back and base.
                                  http://www.ebay.co.uk/bhp/kitchen-drawer-boxes.
                                  Gordon.
                                  #303837
                                  Frances IoM
                                    @francesiom58905
                                    one thing to note with telescopic slides is the accuracy needed in drawers + carcase – you need accurate right angles etc so use jigs + sawbench fences etc if possible.
                                    One dodge is to produce the basic drawer with an attached decorate front but to initially cut a single piece of MDF that covers the full front for all drawers – drill out the holes for the bolts to hold handles easy to align these vertically then attach the full front to the bottom drawer using screws thro these bolt holes then pull out drawer + base + fix each drawer to full panel using prepared holes from inside the drawer – work up the drawers in turn – then unscrew all drawers from front panel, take panel to sawbench and slice each drawer front off the panel – add an extra curf cut(typically 1.5 – 2mm) at bottom of bottom panel to allow clearance – now attach all handles to fronts having counterdrilled holes at rear to allow machine screw heads to be flush (most handle fittings are 5mm thread and you may need to cut down supplied screws to fit + also add a washer) now just attach fronts to each drawer using the created screw holes – bingo all drawer fronts line up vertically + horizontally with just enough clearance
                                    #303838
                                    Bill Dawes
                                      @billdawes
                                      Like Gordon I used some of these ready made runners, they enable drawer making to be really easy, most of the difficult work is already done for you.
                                      Bill D.
                                      #303848
                                      Clive Foster
                                        @clivefoster55965
                                        For workshop purposes you should always use full extension, full load, runners so the whole of the drawer is directly accessible. Many of the kitchen drawer kits are only partial extension so you need to fiddle stuff at the back out past what's in front or even partially unload the drawer first. That gets old real fast. Even those with full extension runners may not have full load capacity at full extension. Need to distribute things to keep the weight towards the back. Specifications also assume the load is evenly distributed. Plonking a small rotary table or decent size chuck in the front corner many be more than the structure or runners can cope with.
                                        If you plan to store larger, heavier items such as chucks, faceplates rotary tables or vices et al consider making the relevant drawers open side with only a minimal lip for the runners. Easier to get a good grip without the sides in the way. Less lift needed to clear the sides too which can also help handling. Often worth packing up the bottom so as to give a straight slide off with no lift. Pretty much mandatory to do this with the common horizontal / vertical rotary table as the handle and dial assembly projects below the base so you either have to lift the base or cut a slot. Slot is not a good idea in practice! Tried it and rapidly re-engieered to pack up the base.
                                        If one side of the cabinet is going to be up against a wall carefully consider what is going in that last bay as loading and unloading will have to be done semi-sideways with no elbow room on the wall side. Good place for sideless drawers or plates of holes for things like drill chucks, collets, et al.
                                        Clive.
                                        #303862
                                        Alan Wood 4
                                          @alanwood4
                                          The Wine Society at Stevenage keeps a stack of empty wooden wine shipment boxes in their shop entrance which you can take for a small contribution to charity.
                                          These make lovely drawers and storage boxes for little cost and they have a nice regional branded image on the end face.
                                          There is the added advantage that if you are desperate and it's after midday you can always sniff the wood.
                                          #303952
                                          clogs
                                            @clogs
                                            HI,
                                            easy to get resin bonded shuttering ply if ur doing a lot and very cheap….I bought 5 pallets (250 sheets) when I last moved, been 13 years and it's almost gone…..hahaha……
                                            always nice to use faced ply but oh so expensive……usually run a round over bit on the edges (router) and have a pre-made jig for the grab holes….no sticky out handles….will try to place a photo in my album….
                                            oh, nice workshop Spurry……..clogs
                                            #303983
                                              Light duty benches (e.g. for electrics) I stick a new top on old units/desks.
                                              Big benches I fabricate from 2×3 studding.
                                                @mike89748
                                                Should we be worried about all these guys comparing their drawers?
                                                I'll get my coat……….
                                                #304001
                                                pgk pgk
                                                  @pgkpgk17461
                                                  Posted by Mike on 24/06/2017 11:54:47:
                                                  ..and do a runner..
                                                  #304262
                                                  Ian S C
                                                    @iansc
                                                    For low cost MDF, or ply, go to a joinery factory (or similar), and see if you can get some cover sheets, these are about 100 mm longer, and 100 mm wider than a standard sheet, and will probably have indents on the outside edges where the straps have dug in a bit. There are two sheets per bundle, and here in NZ you can if you are lucky get them for the taking away, some places sell them for a nominal price.
                                                    Ian S C
                                                    #304481
                                                    Mark Rand
                                                      @markrand96270
                                                      I've just finished putting together a few photos about the bench that I converted from an office table. It might give a few ideas:-
                                                      Mark
