Shell Morlina for Kopp Variator on Colchester Chipmaster
Home Forums Workshop Tools and Tooling Shell Morlina for Kopp Variator on Colchester Chipmaster
  • #18296
    Adam Harris
      @adamharris13683
      #269858
      Adam Harris
        @adamharris13683
        It is said to be very important for the Kopp Variator on these lathes to be lubricated with the correct oil and the recommended one is Shell Morlina S2 BL 10 (which fortunately can also be used for the headstock). I am struggling to find a supplier of small amounts of 1litre – 5 litres, the smallest so far being 20 litres at a price of about £80 which is too much quantity of both oil and money. Can anyone steer me in the right direction for a distributor of small amounts, either online or near Oxfordshire? Many thanks, Adam
        Edited By Adam Harris on 04/12/2016 17:38:23
        #269859
        Hacksaw
          @hacksaw
          You buy it , i'll buy a litre from you…18 litres left to flog !!!
          #269860
          Adam Harris
            @adamharris13683
            Are you in Oxfordshire though?
            #269862
            Hacksaw
              @hacksaw
              No, sussex , put it in a milk bottle , royal mail will never know what it is. wink
              I did ring kopp years ago ,they sold small amounts  for about £20 was it?
              Like you say it is essential to use that oil .
              Edited By Hacksaw on 04/12/2016 17:46:58
              Edited By Hacksaw on 04/12/2016 17:48:41
              #269866
                Out of sheer curiousity, I had a look for equivalents … only to find this emphatic warning: **LINK**
                http://www.allspeeds.co.uk/wp-content/files_mf/whichoilshouldiuse.pdf
                Best buy some for stock !!
                Stuart Bridger
                  @stuartbridger82290
                  Worth trying Caldo, parent company of Hallett Oils. They may be able to do less than the 20l bucket which seems to be the minimum online. No idea when the variator oil was last changed on my Chippie. I am going with if it ain't broke don't fix it. I am an Oxfordshire Shipmaster owner.
                  #269873
                  Mike E.
                    @mikee-85511
                    I was looking for oil for my Mill, and contacted a farm tractor dealer. The dealer only sold what I needed in larger quantities, but phoned a couple of their customers in my area to see if they could help. That worked, an I purchased the small quantity of hydraulic fluid I needed.
                    Perhaps a supplier could direct you to a machine shop which uses the product you need and you could approach them about the small quantity you need; it might be worth a try ?
                    #269893
                    Durhambuilder
                      @durhambuilder
                      I bit the bullet and bought 20 litres of the stuff from Smith and Allan in the summer, I think just over £80 delivered. The same oil is used in the headstock so i did an oil change on that as well. Variator is very very smooth and works well so obviously this oil is the business.
                      From the research I did at the time there were no alternatives.
                      #269974
                      Adam Harris
                        @adamharris13683
                        There is one supplier of small amounts which is Allspeed themselves but the prices are exorbitant (£28.20 for 1 litre delivered, £65 for 5 litres delivered). I am thinking that since it scores 10.0 on the ASTM D445 viscosity scale at 40 deg C which is less than Mobil Nuto H32 (scores 32.0) then I can use it as an upgrade for the beloved Myford as it will have no problem wicking up to the spindle and will offer superior lubrication than the Nuto "hydraulic" stuff which itself sells on fleabay for about £18 per litre. Any thoughts on that, Myford owners?
                        #269987
                          Posted by Adam Harris on 05/12/2016 10:31:49:
                          … I can use it as an upgrade for the beloved Myford …
                          Seems eminently logical, Adam
                          Perhaps a survey of what devices [apart from the Kopp Variator] it is "essential" for, would give use some better understanding of its unique character.
                            The 'Technical Data Sheet' certainly looks promising, but; in view of the Kopp warning note [linked earlier], I had to smile when I read this:
                            "These characteristics are typical of current production. Whilst future production will conform to Shell's specification, variations in these characteristics may occur."
                            http://www.dayanoilco.com/upload/product/1451803631.pdf
                            Edited By Michael Gilligan on 05/12/2016 11:51:52
                            #270005
                            Adam Harris
                              @adamharris13683
                              Quite so Michael! I was thinking that one wants some degree of viscosity so it actually remains on the surfaces needing lubrication (!) but then since the Myford is a total loss lubrication system, the downside would be that I might merely end up going through a bit more quantity of the Shell Morlina S2 BL 10 than I would the Mobil Nuto H32 – I suspect the quantities increase will not result in an empty 20 litre drum in my lifetime!
                              #270064
                              MW
                                @mw27036
                                I take it not everything behaves in a "Newtonian" manner? Which this oil happens to not be and therefore trumps all competition? face 22 Even if they can prove the same? Sounds a little fishy to me.
                                Michael W
                                #270085
                                Adam Harris
                                  @adamharris13683
                                  Well I have grimaced and bought the 20 litre drum today so if anyone wants a cheap price for 1 litre or 5 litres…..
                                  Edited By Adam Harris on 05/12/2016 19:23:04
                                  #270090
                                  Hacksaw
                                    @hacksaw
                                    I'd have a litre .. could you post me a " Starter motor " ?smiley
                                    Or what exciting things could I see in Oxford on a day trip after xmas ? Like cars, planes , engines ..museums ?
                                    #270093
                                    Adam Harris
                                      @adamharris13683
                                      Didcot Railway Centre museum has a very good selection of steam engines and all sorts….
                                      #270466
                                      charadam
                                        @charadam
                                        "Well I have grimaced and bought the 20 litre drum today so if anyone wants a cheap price for 1 litre or 5 litres….."
                                        Adam,
                                        Please check your pmail.
                                        Thanks,
                                        Charles
                                        #270473
                                        john fletcher 1
                                          @johnfletcher1
                                          For Myford owner who need Esso Nuto 44, I suggest you take a clean, empty milk carton to your agricultural dealers, ship chandlers or earth moving plant operators premise, its hydraulic fluid, we buy it local for about £2 a can. John
