5/16″x36 TPI die nut wanted
Home Forums Workshop Tools and Tooling 5/16″x36 TPI die nut wanted
  • #258045
    Dave Harding 1
      @daveharding1
      Any body know were I can get a 5/16×36 TPI die nut. Tracy tools don't have them in stock. So I am stumped as were to find one.
      #18206
      Dave Harding 1
        @daveharding1
        #258047
        nigel jones 5
          @nigeljones5
          ARE U SURE ITS X36?? X 32 IS NORMAL
          #258056
          I.M. OUTAHERE
            @i-m-outahere
            5/16x 36 unfs .
            Tracy tools show no stock but can they order one in for you ?
            Have you tried ebay , amazon etc ?
            Just in case any one here in Australia is looking for odd sized taps and dies LPR Toolmakers have a good range and can get specials made for you – no connection other than a happy customer !
            Ian.
            #258066
            Brian G
              @briang
              Are you sure it is UNS? There is a 5/16 x 36 Whitform tap on eBay right now, I suppose almost anything is possible.
              Brian
              #258068
                Posted by Brian G on 27/09/2016 09:12:05:
                … There is a 5/16 x 36 Whitform tap on eBay right now, I suppose almost anything is possible.
                Like using the tap to make a die, to clean up the thread ? devil
                … I think this might be an easier approach:
                http://www.ebay.co.uk/itm/New-5-16-36-Right-Hand-Die-5-16-36-TPI-/150882958722?hash=item2321533d82:g~0AAOSwv0tVGOFx
                Just gotta love this forum software … inserts a smiley in a web link
                Edited By Michael Gilligan on 27/09/2016 09:31:14
                #258222
                  With a possible three week waiting time, and iffy chinese quality at that price, a tap, hacksaw blade and a bit of heat treatment might be a far better, or more satisfying, proposition. It would for me!
                  #258227
                    Posted by not done it yet on 27/09/2016 21:57:13:
                    I suppose that would depend upon the material and purpose of thread in question, and its present condition. … [all being, as yet unspecified].
                    Dave Harding 1
                      @daveharding1
                      I have a tap but no die. I am working with aluminium tubing it was originally a Hornady cartridge over all length gauge. I snapped the threaded end off and want to re cut it so I don't have to spend £50 for a new one.
                      #258250
                      I.M. OUTAHERE
                        @i-m-outahere
                        Re cut it on the lathe if the gauge is the straight OAL gauge type
                        If it is a hornady product the likelihood of it being Whitworth are zero and more likely to unfs which i would guess is a 60 deg thread .
                        #258253
                          Often the case that insufficient relevant detail is included, so responses are made taking into account the suspected application. Die nuts are generally used for cleaning up damaged threads and one might expect the OP to ask for what he/she requires. Making a die nut is not that difficult.
                          #258258
                            < no further comment >
                            #258753
                            Dave Harding 1
                              @daveharding1
                              As my original post said I want to source a die nut in 5/16×36 TPI what I want to use it for is irrelevant.
                              You either know were I can get one or you don't. It sounds like you don't. That's all I wanted to know.
                              #258758
                                So, Dave … Did you order the one I found for you ?
                                If you did; then please report back as to whether it was worth the price of half a pint of Bitter.
