Quick question- wondered if anyone knows the minimum distance between spindle centre and the wall behind the lathe (Myford 7 series), while still having enough clearance to open the primary belt drive cover. Manual suggests 13.5”, but not sure if this allows the cover to swing open… unless maximum crossslide travel (long cross slide on S7b I believe?) is the limiting point?
My lathe is in storage while my workshop is gradually being built- and wanted to check the dimension so I can position the door opening to allow for long stock to run through the headstock and into the world outside when necessary…
Edited By RichardN on 01/05/2019 21:38:14
