Will end up fiddling with an inverter and the pulley ratios till I get to 1000RPM then I think.
With the labeling, still not sure how strongly I want to try and keep the lathe looking of its time. If I try to restore then botch the current label I might take that as a sign from above to modernise and use a printer.
Will have to look into making some drip feed oilers to replace the tiny oil cups currently in place.
More questions
1. What would a reasonable maximum size be for chucks? With the 9×24" capacity and 1.5" spindle nose. A manual I got for a Mk2 lathe mentioned a backplate for 6" scroll chucks and 8" 4 jaw chucks. However the Mk2 had a 1.75" nose and ran in taper roller bearings.
I did find it curious that the manual lists separately a 4.5" back plate for a Taylor chuck. I guess they are heavier than the chucks of other makers?
Was thinking about purchasing this chuck
2. There is only 1/2" between the top slide and center height. 1/8" less than a myford. Using arceuros 000 tool post would give me 8.25mm of tool space. Was wondering at what point the thickness of the tool stops being the weakest link of the lathe. 8mm seems pretty thin being smaller than the tooling I use on my 7×12 mini lathe. I am debating taking off the entire top slide and bolting one big tool post onto the cross slide. I have some 25×25 tooling that has been sitting around and I have been debating slitting it into smaller tooling since forever but this might save me that job.
3. Anyone know some plans for a home made milling attachment? I have a vague plan of using round rod to make the slides like a Unimat but would be reassuring to follow a tried and tested plan.
